I have followed the tutorial to integrate nest in HA to the letter, I get to the end, but when I have to go back to the HA integration, I get “ERROR”:
Logger: aiohttp.server
Source: helpers/config_entry_oauth2_flow.py:205
First occurred: 11:20:09 (2 occurrences)
Last logged: 11:25:55
Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 81, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 136, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 171, in get
return await super().get(request, flow_id)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 96, in get
result = await self._flow_mgr.async_configure(flow_id)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 286, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 374, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 306, in async_step_creation
token = await self.flow_impl.async_resolve_external_data(self.external_data)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 169, in async_resolve_external_data
return await self._token_request(
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 205, in _token_request
resp.raise_for_status()
File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 1004, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 401, message='Unauthorized', url=URL('https://www.googleapis.com/oauth2/v4/token')
I use Home Assistant 2023.1.4 on synology docker
THX
