I just started getting this error seemingly out of the blue:
2021-01-14 21:34:09 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry ConBee II, s/n: DE2149353 - dresden elektronik ingenieurtechnik GmbH for zha
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 236, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 100, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 157, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.8/site-packages/zigpy/application.py", line 64, in new
await app._load_db()
File "/usr/local/lib/python3.8/site-packages/zigpy/application.py", line 56, in _load_db
await self._dblistener.load()
File "/usr/local/lib/python3.8/site-packages/zigpy/appdb.py", line 463, in load
await self._load_attributes()
File "/usr/local/lib/python3.8/site-packages/zigpy/appdb.py", line 478, in _load_attributes
dev = self._application.get_device(ieee)
File "/usr/local/lib/python3.8/site-packages/zigpy/application.py", line 390, in get_device
return self.devices[ieee]
KeyError: 00:15:8d:00:01:ae:a6:b7
I was able to set up ZHA through the Integration page with no problems and add a bunch of devices. Then I restarted HA an this error keeps showing up. I am running HA in a Proxmox VM. The ConBee II stick i being passed through. It showed up fine when I first configured the integration.
What could the issue be?
