Hello community,
a view time ago, i’ve installed HA on a RPI4 as described. Installation of RaspberryMatic and importing the configuration works well. USB Antenna is working well. but right now, the system is only starting in recovery mode without any functionality.
Right now, i get the following error message in my web interface
Error loading /config/configuration.yaml: while scanning for the next token found character ‘\t’ that cannot start any token
in “/config/configuration.yaml”, line 14, column*
I’ve never edited any yaml file in HA
in the configuration.yaml file at line 14 is the following value
Thanks for your quick response. I’ve checked and changed the TAB in spaces and restart the HA device. Now i get a new error
2023-11-19 15:54:24.787 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] while parsing a block mapping
in “/config/configuration.yaml”, line 13, column 7
expected , but found ‘’
in “/config/configuration.yaml”, line 18, column 9
2023-11-19 15:54:24.789 ERROR (MainThread) [homeassistant.bootstrap] Failed to parse configuration.yaml: while parsing a block mapping in “/config/configuration.yaml”, line 13, column 7
expected , but found ‘’ in “/config/configuration.yaml”, line 18, column 9.
got HA back in operation without error messages and can be tricky depending my spaces in the file.
No space at the beginng of the value bring up an error message
3 spaces (which were actually already in the file before). System reboot solved the issue.
