Getting the following error from 0.92
Integration persistense not found when trying to verify its sensor platform.
6:47 PM components/hassio/init.py (ERROR)
Got unexpected response: None
6:46 PM components/updater/init.py (ERROR)
You are using a custom integration for persistence which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
6:36 PM loader.py (WARNING)
Looking like 0.92 is having issues with custom components. Anyone have a work around?
