Error loading /home/homeassistant/.homeassistant/configuration.yaml: while parsing a block mapping in "/home/homeassistant/.homeassistant/configuration.yaml", line 2, column 1 expected <block end>, but found '<block sequence start>'
default_config:
tts:
  • platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
duckdns:
domain: casamia
access_token: miotoken
http:
ssl_certificate: /home/homeassistant/dehydrated/certs/casamia.duckdns.org/fullchain.pem
ssl_key: /home/homeassistant/dehydrated/certs/casamia.duckdns.org/privkey.pemsensor
I’m not able to understand and resolve the error line given by home assistant
Can you format your code correctly using the code block button please
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
 - platform: google_translate
duckdns:
  domain: casamia
  access_token: mytoken
http:
 - platform: cert_expiry
   host: casabusato.duckdns.org
   port: 8123
    sensors:
      certificate_expiry:
        friendly_name: "Scadenza certificato"
        value_template: "{{ (( as_timestamp(states('sensor.cert_expiry_timestamp_casamia_duckdns_org_8123')) | int - as_timestamp(now()) | int ) /60/60/24 ) | int }}"
        unit_of_measurement: "Giorni"
        icon_template: mdi:certificate
spotify:
  client_id: myid
  client_secret: mysecret
api:
alexa:
  smart_home:
hacs:
  token: mytoken
Looks like your missing a space before the - on the line below tts:
The problem is your -platfrom: cert_expiry. That’s not a valid configuration for those fields also, its now configured through the UI.
spacing doesn’t matter as long as all fields are in line below the -. YOu can use 2, 3 1, or zero spaces
This is the full configuration.yaml
Yes as I said, this is wrong and not valid.
The cert expiry section doesn’t belong in http
http:
   host: casamia.duckdns.org
   port: 8123
Yes… it’s wrong, remove the cert_expiry lines
There’s also sensor wrongly appended to you SSL cert url
I’ve deleted it, but the problem persist
I’m assuming you have something else wrong, post the config again
Paste what you have now
default_config:
# Text to speech
tts:
duckdns:
  domain: casamia
  access_token: 0e97ca68-2a0f-49c6-a69a-427c5abf5d9b
http:
  ssl_certificate: /home/homeassistant/dehydrated/certs/casabusato.duckdns.org/fullchain.pem
  ssl_key: /home/homeassistant/dehydrated/certs/casabusato.duckdns.org/privkey.pemsensor
   port: 8123
    sensors:
      certificate_expiry:
spotify:
  client_id: ...
  client_secret: ...
api:
alexa:
  smart_home:
hacs:
  token: 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
You left part of the cirt_expiry configuration there…
as @samnewman86 said, you added extra ‘sensor’ at the end of your pem file
the problem appeared when I’ve opened with visual code the configuration.yaml for the first time, and asked me to correct some code line, as I did, everything just stopped working.
The point is that with this configuration everything worked just fine before
Before it all got changed you mean
You didn’t read the breaking changes. You’re suppossed to switch to the UI for the cert_expiry integration. I feel like a broken record here
