I try docker home-assistant 115.2, also try latest version but same issue
Docker stop with error below
Status: Downloaded newer image for homeassistant/home-assistant:0.115.2
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
Error loading shared library libz.so.1: No such file or directory (needed by /lib/libkmod.so.2)
Error loading shared library libcrypto.so.1.1: No such file or directory (needed by /lib/libkmod.so.2)
Error relocating /lib/libkmod.so.2: OPENSSL_sk_value: symbol not found
Error relocating /lib/libkmod.so.2: PKCS7_SIGNER_INFO_get0_algs: symbol not found
Error relocating /lib/libkmod.so.2: OBJ_obj2nid: symbol not found
Error relocating /lib/libkmod.so.2: gzclose: symbol not found
Error relocating /lib/libkmod.so.2: X509_ALGOR_get0: symbol not found
Error relocating /lib/libkmod.so.2: ASN1_INTEGER_to_BN: symbol not found
Error relocating /lib/libkmod.so.2: X509_NAME_get_entry: symbol not found
Error relocating /lib/libkmod.so.2: BN_num_bits: symbol not found
Error relocating /lib/libkmod.so.2: X509_NAME_ENTRY_get_data: symbol not found
Error relocating /lib/libkmod.so.2: ASN1_STRING_get0_data: symbol not found
Error relocating /lib/libkmod.so.2: d2i_PKCS7_bio: symbol not found
Error relocating /lib/libkmod.so.2: gzdopen: symbol not found
Error relocating /lib/libkmod.so.2: PKCS7_get_signer_info: symbol not found
Error relocating /lib/libkmod.so.2: BIO_new_mem_buf: symbol not found
Error relocating /lib/libkmod.so.2: gzerror: symbol not found
Error relocating /lib/libkmod.so.2: X509_NAME_ENTRY_get_object: symbol not found
Error relocating /lib/libkmod.so.2: X509_NAME_entry_count: symbol not found
Error relocating /lib/libkmod.so.2: BN_bn2bin: symbol not found
Error relocating /lib/libkmod.so.2: PKCS7_free: symbol not found
Error relocating /lib/libkmod.so.2: gzread: symbol not found
Error relocating /lib/libkmod.so.2: BIO_free: symbol not found
Error relocating /lib/libkmod.so.2: BN_free: symbol not found
Error relocating /lib/libkmod.so.2: ASN1_STRING_length: symbol not found
[cont-init.d] udev.sh: exited 127.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
docker version
Client: Docker Engine - Community
Version: 19.03.13
API version: 1.40
Go version: go1.13.15
Git commit: 4484c46
Built: Wed Sep 16 17:03:40 2020
OS/Arch: linux/arm64
Experimental: false
Server: Docker Engine - Community
Engine:
Version: 19.03.13
API version: 1.40 (minimum version 1.12)
Git commit: 4484c46
Built: Wed Sep 16 17:02:11 2020
Experimental: false
containerd:
Version: 1.3.7
GitCommit: 8fba4e9a7d01810a393d5d25a3621dc101981175
runc:
Version: 1.0.0-rc10
GitCommit: dc9208a3303feef5b3839f4323d9beb36df0a9dd
docker-init:
Version: 0.18.0
GitCommit: fec3683
locate libz.so.1
/usr/lib/aarch64-linux-gnu/libz.so.1
/usr/lib/aarch64-linux-gnu/libz.so.1.2.11
/var/lib/docker/overlay2/0a47521ae99d9f881c2c262749cd0f70c90ed32315b47c0c67f67323070cdd0b/diff/lib/aarch64-linux-gnu/libz.so.1.2.11
/var/lib/docker/overlay2/0c595b7bf3fbaaa48aed9280601c77c497a4ac9bc6d27bbc8b731780326d04f1/diff/lib/libz.so.1.2.11
/var/lib/docker/overlay2/5cbe83796343ea4ccc5b8eb574a8319b186b40f411e8f4f6494a0c0e4c250c2d/diff/lib/x86_64-linux-gnu/libz.so.1.2.11
locate libcrypto.so.1.1
/usr/lib/aarch64-linux-gnu/libcrypto.so.1.1
What could be the issue?
Please help
