Would appreciate if somebody could help me debug my system, have had several issues since 0.113…
My instance runs fine for hours then all of a sudden I start getting numerous errors and it seems to get stuck in a loop?
This is causing increased CPU, PI temperature and a general slow down of the system, AppDaemon Apps and Automations
Below is just a small extract from part of my core log.
2020-08-06 14:58:15 ERROR (MainThread) [pyhaversion] Timeout error fetching version information from Hassio,
2020-08-06 14:58:15 INFO (MainThread) [backoff] Backing off call_api(...) for 0.1s (asyncio.exceptions.TimeoutError)
2020-08-06 14:58:15 INFO (MainThread) [backoff] Backing off call_api(...) for 0.9s (asyncio.exceptions.TimeoutError)
2020-08-06 14:58:15 WARNING (MainThread) [homeassistant.components.sensor] Updating systemmonitor sensor took longer than the scheduled update interval 0:00:30
2020-08-06 14:58:18 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating amcrest binary_sensor took longer than the scheduled update interval 0:00:05
2020-08-06 14:58:22 WARNING (MainThread) [homeassistant.components.camera] Updating amcrest camera took longer than the scheduled update interval 0:00:15
2020-08-06 14:58:23 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating amcrest binary_sensor took longer than the scheduled update interval 0:00:05
2020-08-06 14:58:28 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating amcrest binary_sensor took longer than the scheduled update interval 0:00:05
2020-08-06 14:58:33 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating amcrest binary_sensor took longer than the scheduled update interval 0:00:05
2020-08-06 14:58:33 WARNING (MainThread) [homeassistant.components.calendar] Updating google calendar took longer than the scheduled update interval 0:01:00
2020-08-06 14:58:36 INFO (MainThread) [backoff] Backing off call_api(...) for 1.9s (asyncio.exceptions.TimeoutError)
2020-08-06 14:58:36 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:01:00
2020-08-06 14:58:37 INFO (MainThread) [backoff] Backing off call_api(...) for 2.0s (asyncio.exceptions.TimeoutError)
2020-08-06 15:00:58 WARNING (MainThread) [homeassistant.components.binary_sensor] Updating amcrest binary_sensor took longer than the scheduled update interval 0:00:05
2020-08-06 15:01:02 WARNING (MainThread) [homeassistant.helpers.entity] Update of camera.amcrest_camera is taking over 10 seconds
Version
System Health
arch aarch64
chassis embedded
dev false
docker true
docker_version 19.03.8
hassio true
host_os HassOS 5.0
installation_type Home Assistant OS
os_name Linux
os_version 4.19.127-v8
python_version 3.8.3
supervisor 229
timezone Europe/London
version 0.113.3
virtualenv false
Lovelace
dashboards 4
mode storage
resources 15
views 1
