ERROR (MainThread) [supervisor.docker.manager] failed to register layer
Hi everyone, I bought a Raspberry Pi to install HA on it, but I can’t get it to work. Please help. I was running HA on a virtual machine before.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[21:19:02] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[21:19:02] INFO: Starting local supervisor watchdog...
2025-11-20 21:19:06.489 INFO (MainThread) [__main__] Initializing Supervisor setup
2025-11-20 21:19:06.649 INFO (MainThread) [supervisor.coresys] Setting up coresys for machine: raspberrypi4-64
2025-11-20 23:19:06.660 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/aarch64-hassio-supervisor with version 2025.11.4
2025-11-20 23:19:06.660 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
2025-11-20 23:19:16.488 INFO (MainThread) [supervisor.docker.manager] Cleanup images: ['ghcr.io/home-assistant/aarch64-hassio-supervisor:2025.11.1']
2025-11-20 23:19:21.128 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize
2025-11-20 23:19:21.137 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-11-20 23:19:21.140 INFO (MainThread) [__main__] Setting up Supervisor
2025-11-20 23:19:21.367 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
2025-11-20 23:19:21.642 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
2025-11-20 23:19:21.648 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
2025-11-20 23:19:21.654 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
2025-11-20 23:19:21.658 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
2025-11-20 23:19:21.660 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
2025-11-20 23:19:21.663 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
2025-11-20 23:19:21.665 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
2025-11-20 23:19:21.669 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
2025-11-20 23:19:21.672 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
2025-11-20 23:19:21.673 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
2025-11-20 23:19:22.659 INFO (MainThread) [supervisor.host.services] Updating service information
2025-11-20 23:19:22.682 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-11-20 23:19:24.682 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-11-20 23:19:24.987 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
2025-11-20 23:19:25.116 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 16.3 / BootSlot A
2025-11-20 23:19:25.124 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
2025-11-20 23:19:25.133 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-cli with version 2025.09.0
2025-11-20 23:19:30.544 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-dns with version 2025.08.0
2025-11-20 23:19:30.986 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
2025-11-20 23:19:31.006 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-audio with version 2025.08.0
2025-11-20 23:19:31.048 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-observer with version 2025.02.0
2025-11-20 23:19:31.084 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/aarch64-hassio-multicast with version 2025.08.0
2025-11-20 23:19:31.118 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
2025-11-20 23:19:31.123 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version landingpage
2025-11-20 23:19:31.558 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
2025-11-20 23:19:31.576 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository
2025-11-20 23:19:31.577 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository
2025-11-20 23:19:31.577 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository
2025-11-20 23:19:31.587 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/d5369777 repository
2025-11-20 23:19:32.324 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on 'Folding@home' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2025-11-20 23:19:32.339 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on 'Tailscale' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2025-11-20 23:19:32.352 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on 'MQTT IO' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2025-11-20 23:19:32.447 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on 'Nginx Proxy Manager' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2025-11-20 23:19:32.469 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on 'Glances' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2025-11-20 23:19:32.548 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on 'Log Viewer' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2025-11-20 23:19:32.576 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on 'Overseerr' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2025-11-20 23:19:32.631 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on 'Grocy' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2025-11-20 23:19:32.639 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on 'Traccar' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2025-11-20 23:19:32.667 WARNING (SyncWorker_0) [supervisor.addons.validate] Add-on 'InfluxDB' uses deprecated 'codenotary' field in config. This field is no longer used and will be ignored. Please report this to the maintainer.
2025-11-20 23:19:32.763 INFO (MainThread) [supervisor.store] Loading add-ons from store: 81 all - 81 new - 0 remove
2025-11-20 23:19:32.874 INFO (MainThread) [supervisor.addons.manager] Found 0 installed add-ons
2025-11-20 23:19:32.958 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
2025-11-20 23:19:32.958 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
2025-11-20 23:19:32.959 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
2025-11-20 23:19:32.959 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup
2025-11-20 23:19:32.959 INFO (MainThread) [supervisor.resolution.checks.base] Run check for deprecated_addon/addon
2025-11-20 23:19:32.960 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-11-20 23:19:32.961 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
2025-11-20 23:19:32.961 INFO (MainThread) [supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
2025-11-20 23:19:32.961 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-11-20 23:19:32.962 INFO (MainThread) [supervisor.resolution.checks.base] Run check for duplicate_os_installation/system
2025-11-20 23:19:33.087 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-11-20 23:19:33.087 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup
2025-11-20 23:19:33.088 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-11-20 23:19:33.089 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
2025-11-20 23:19:34.019 INFO (MainThread) [supervisor.os.manager] Rauc: slot A - activated slot kernel.0, marked slot kernel.0 as good
2025-11-20 23:19:34.065 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2025-11-20 23:19:34.615 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
2025-11-20 23:19:34.630 INFO (MainThread) [supervisor.addons.manager] Phase 'system' starting 0 add-ons
2025-11-20 23:19:34.631 INFO (MainThread) [supervisor.addons.manager] Phase 'services' starting 0 add-ons
2025-11-20 23:19:34.642 INFO (MainThread) [supervisor.core] Skipping start of Home Assistant
2025-11-20 23:19:34.642 INFO (MainThread) [supervisor.addons.manager] Phase 'application' starting 0 add-ons
2025-11-20 23:19:34.661 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
2025-11-20 23:19:34.662 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
2025-11-20 23:19:34.663 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2025.11.2
2025-11-20 23:19:34.664 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2025.11.2.
2025-11-20 23:19:34.669 INFO (MainThread) [supervisor.host.info] Updating local host information
2025-11-20 23:19:34.670 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-11-20 23:19:34.671 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-11-20 23:19:34.683 INFO (MainThread) [supervisor.core] Supervisor is up and running
2025-11-20 23:19:34.685 INFO (MainThread) [__main__] Running Supervisor
2025-11-20 23:19:34.689 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-11-20 23:19:34.690 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-11-20 23:19:34.691 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2025-11-20 23:19:34.692 INFO (MainThread) [supervisor.resolution.module] Create new suggestion create_full_backup - system / None
2025-11-20 23:19:34.692 INFO (MainThread) [supervisor.resolution.module] Create new issue no_current_backup - system / None
2025-11-20 23:19:34.693 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-11-20 23:19:34.716 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-11-20 23:19:34.716 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-11-20 23:19:34.717 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-11-20 23:19:34.724 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-11-20 23:19:34.725 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-11-20 23:19:34.727 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disk_lifetime/system
2025-11-20 23:19:34.734 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-11-20 23:19:34.734 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-11-20 23:19:34.832 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-11-20 23:19:34.833 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-11-20 23:19:34.833 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-11-20 23:19:35.959 INFO (MainThread) [supervisor.host.services] Updating service information
2025-11-20 23:19:35.985 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-11-20 23:19:36.677 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-11-20 23:19:36.711 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2025-11-20 23:22:48.811 ERROR (MainThread) [supervisor.docker.manager] failed to register layer: mkdir /mnt/data/docker/overlay2/6fd4c2edc6830787269d7d5c3bd85e35e733497d45b556edec0e28f34e964663: bad message
2025-11-20 23:22:48.814 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:22:48.815 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:22:48.816 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:22:48.817 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:22:48.818 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:22:48.819 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:22:48.821 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2025-11-20 23:23:18.823 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2025.11.2
2025-11-20 23:23:18.824 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2025.11.2.
2025-11-20 23:26:16.833 ERROR (MainThread) [supervisor.docker.manager] failed to register layer: exit status 1: unpigz: skipping: <stdin>: corrupted -- incomplete deflate data
2025-11-20 23:26:16.834 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:26:16.835 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:26:16.836 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2025-11-20 23:26:46.840 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2025.11.2
2025-11-20 23:26:46.841 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2025.11.2.
2025-11-20 23:28:13.669 ERROR (MainThread) [supervisor.docker.manager] failed to register layer: unexpected EOF
2025-11-20 23:28:13.670 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:28:13.671 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:28:13.672 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:28:13.673 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:28:13.674 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:28:13.675 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
2025-11-20 23:28:43.680 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2025.11.2
2025-11-20 23:28:43.681 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2025.11.2.
2025-11-20 23:29:30.070 ERROR (MainThread) [supervisor.docker.manager] failed to register layer: error creating overlay mount to /mnt/data/docker/overlay2/596b7797f666c1773d2a18cd8d4273200acd016f26fceafce0e8258e5c06a43c/merged: invalid argument
2025-11-20 23:29:30.071 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:29:30.072 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:29:30.073 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:29:30.074 WARNING (MainThread) [supervisor.jobs] Removing incomplete job Pulling container image layer from job manager
2025-11-20 23:29:30.074 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
