ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 13:03:30 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-04-27 13:03:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-04-27 13:03:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-04-27 13:03:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-04-27 13:03:30 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-04-27 13:03:30 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-04-27 13:03:30 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-04-27 13:03:30 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-04-27 13:06:22 INFO (SyncWorker_4) [supervisor.docker.interface] Restarting homeassistant/qemux86-64-homeassistant
21-04-27 13:06:38 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-04-27 13:06:53 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-04-27 13:06:53 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-04-27 13:07:45 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-04-27 14:03:30 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-04-27 14:03:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-04-27 14:03:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-04-27 14:03:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-04-27 14:03:30 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-04-27 14:03:30 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-04-27 14:03:30 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-04-27 14:03:30 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-04-27 14:03:32 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
21-04-27 14:04:52 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
21-04-27 14:04:52 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
21-04-27 14:04:55 INFO (MainThread) [supervisor.store] Loading add-ons from store: 66 all - 0 new - 0 remove
21-04-27 14:04:56 INFO (MainThread) [supervisor.store] Loading add-ons from store: 66 all - 0 new - 0 remove
21-04-27 14:12:21 INFO (MainThread) [supervisor.host.info] Updating local host information
21-04-27 14:12:22 INFO (MainThread) [supervisor.host.services] Updating service information
21-04-27 14:12:23 INFO (MainThread) [supervisor.host.network] Updating local network information
21-04-27 14:12:26 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
21-04-27 14:12:26 INFO (MainThread) [supervisor.host] Host information reload completed
21-04-27 15:03:30 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
21-04-27 15:03:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
21-04-27 15:03:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
21-04-27 15:03:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
21-04-27 15:03:30 INFO (MainThread) [supervisor.resolution.check] System checks complete
21-04-27 15:03:30 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
21-04-27 15:03:30 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
21-04-27 15:03:30 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-04-27 15:29:37 INFO (SyncWorker_2) [supervisor.docker.interface] Restarting homeassistant/qemux86-64-homeassistant
21-04-27 15:29:45 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-04-27 15:30:00 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-04-27 15:30:01 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-04-27 15:30:43 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:31:19 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:31:55 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:32:31 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:33:07 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:33:43 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:34:46 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-04-27 15:35:12 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-04-27 15:38:09 INFO (SyncWorker_4) [supervisor.docker.interface] Restarting homeassistant/qemux86-64-homeassistant
21-04-27 15:38:26 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-04-27 15:38:39 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
21-04-27 15:38:39 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
21-04-27 15:39:29 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:40:05 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:40:41 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:41:17 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:41:53 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:42:29 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:43:05 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:43:41 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:
21-04-27 15:44:35 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
What do I do?
I have same issue…
so I tried to restore my HomeAssistant from snapshots
but, snapshots ressotre version also has same problem
so… I checked core and supervisor logs
in my case, after “waiting to instalation finish~~ hasc, dhcp”
my supervisor and core communication disconnected.
with same logs with you
I thinks there is no way… so I reinstall all system
I got the same issue, but it seems not to break anything. Anyone has input on this?
me too… how can this be solved?
