Hello friends! I’m very new to using ESPHome and trying to convert a cloud-controlled smart-plug.
I have the US version of the Elekcity ESW01 plug. I have been working from this example for an EU plug and the GOIP mapping is identical (according to the Tasmota devices website) except for the US version listing a GPIO15 mapping to HLWBL SEL.
When I try to download the compiled firmware I immediately receive this error:
INFO Reading configuration /config/esphome/esph-plug-01.yaml...
ERROR Error while reading config: Invalid YAML syntax:
mapping values are not allowed here
in "/config/esphome/esph-plug-01.yaml", line 70, column 17:
on_value:
I have tried looking for additional examples of using on_value:
on the ESPHome Devices website but have been unsuccessful.
Here is the full code
esphome:
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "redacted"
ota:
password: "redacted"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esph-Plug-01 Fallback Hotspot"
captive_portal:
status_led:
pin:
number: GPIO5
output:
- platform: gpio
pin: GPIO16
switch:
- platform: gpio
pin: GPIO4
restore_mode: RESTORE_DEFAULT_ON
on_turn_on:
- output.turn_on: led1
on_turn_off:
- output.turn_off: led1
binary_sensor:
- platform: gpio
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: true
on_press:
- switch.toggle: switch1
- platform: hlw8012
sel_pin: 0
cf_pin: GPIO13
cf1_pin: GPIO12
voltage:
power:
on_value: #<-- Error indicated here...
- sensor.template.publish:
state: !lambda 'return id(hlw8012_power).state / id(hlw8012_voltage).state;'
update_interval: 60s
initial_mode: VOLTAGE
change_mode_every: 4294967295 # basically never
name: "Current (calculated)"
I have tried changing the indent sequence and copy/paste the code directly from the example with no change in the results.
If anyone has a suggestion or a pointer to what I’m doing wrong it would be appreciated.
Many Thanks!
