I was using HA 114; I’ve tried to update by pressing the “update” button on the dashboard. After several minutes of doing nothing, I went on to the terminal and issued a “config pip3 install --upgrade homeassistant”. A bunch of read text with ERRORS all over the place popped up. I reboot HA and it seems 116 is now installed. I’m worried some dependencies might be missing. Should I worry?
➜ config pip3 install --upgrade homeassistant
Collecting homeassistant
Downloading homeassistant-0.116.2-py3-none-any.whl (9.4 MB)
|████████████████████████████████| 9.4 MB 23 kB/s
Requirement already satisfied, skipping upgrade: pyyaml==5.3.1 in /usr/lib/python3.8/site-packages (from homeassistant) (5.3.1)
Collecting requests==2.24.0
Downloading requests-2.24.0-py2.py3-none-any.whl (61 kB)
|████████████████████████████████| 61 kB 7.5 kB/s
Collecting certifi>=2020.6.20
Downloading certifi-2020.6.20-py2.py3-none-any.whl (156 kB)
|████████████████████████████████| 156 kB 2.8 MB/s
Collecting voluptuous==0.12.0
Downloading voluptuous-0.12.0-py3-none-any.whl (29 kB)
Collecting voluptuous-serialize==2.4.0
Downloading voluptuous_serialize-2.4.0-py3-none-any.whl (6.7 kB)
Requirement already satisfied, skipping upgrade: pip>=8.0.3 in /usr/lib/python3.8/site-packages (from homeassistant) (20.1.1)
Requirement already satisfied, skipping upgrade: pytz>=2020.1 in /usr/lib/python3.8/site-packages (from homeassistant) (2020.1)
Collecting bcrypt==3.1.7
Downloading bcrypt-3.1.7.tar.gz (42 kB)
|████████████████████████████████| 42 kB 10 kB/s
Installing build dependencies ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 /usr/lib/python3.8/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-g4trlnq4/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org
/simple -- 'setuptools>=40.8.0' wheel 'cffi>=1.1; python_implementation != '"'"'PyPy'"'"''
cwd: None
Complete output (86 lines):
Collecting setuptools>=40.8.0
Downloading setuptools-50.3.0-py3-none-any.whl (785 kB)
Collecting wheel
Downloading wheel-0.35.1-py2.py3-none-any.whl (33 kB)
Collecting cffi>=1.1
Downloading cffi-1.14.3.tar.gz (470 kB)
Collecting pycparser
Downloading pycparser-2.20-py2.py3-none-any.whl (112 kB)
Using legacy setup.py install for cffi, since package 'wheel' is not installed.
Installing collected packages: setuptools, wheel, pycparser, cffi
Running setup.py install for cffi: started
Running setup.py install for cffi: finished with status 'error'
command: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-_3lmzkpd/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-_3lmzkpd/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"',
open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-x_9pk__8/install-record.txt --single-version-externally-managed --prefix /
tmp/pip-build-env-g4trlnq4/overlay --compile --install-headers /tmp/pip-build-env-g4trlnq4/overlay/include/python3.8/cffi
cwd: /tmp/pip-install-_3lmzkpd/cffi/
Complete output (68 lines):
Package libffi was not found in the pkg-config search path.
Perhaps you should add the directory containing `libffi.pc'
to the PKG_CONFIG_PATH environment variable
Package 'libffi', required by 'virtual:world', not found
unable to execute 'gcc': No such file or directory
No working compiler found, or bogus compiler options passed to
the compiler from Python's standard "distutils" module. See
the error messages above. Likely, the problem is not related
to CFFI but generic to the setup.py of any Python package that
tries to compile C code. (Hints: on OS/X 10.8, for errors about
-mno-fused-madd see http://stackoverflow.com/questions/22313407/
Otherwise, see https://wiki.python.org/moin/CompLangPython or
the IRC channel #python on irc.freenode.net.)
Trying to continue anyway. If you are trying to install CFFI from
a build done in a different context, you can ignore this warning.
running install
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.8
creating build/lib.linux-armv7l-3.8/cffi
copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/recompiler.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/lock.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/__init__.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/error.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/cparser.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/verifier.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/commontypes.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/model.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/api.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.8/cffi
copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.8/cffi
copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.8/cffi
copying cffi/_embedding.h -> build/lib.linux-armv7l-3.8/cffi
copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.8/cffi
running build_ext
building '_cffi_backend' extension
creating build/temp.linux-armv7l-3.8
creating build/temp.linux-armv7l-3.8/c
gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fomit-frame-pointer -g -fno-semantic-interposition -fomit-frame-pointer -g -fno-semantic-interposition -fomit-frame-pointer -g -fno-semantic-interposition -DT
HREAD_STACK_SIZE=0x100000 -fPIC -I/usr/include/ffi -I/usr/include/libffi -I/usr/include/python3.8 -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.8/c/_cffi_backend.o
error: command 'gcc' failed with exit status 1
ERROR: Command errored out with exit status 1: /usr/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-_3lmzkpd/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-_3lmzkpd/cffi/setup.py'"'"';f=
getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-x_9pk__8/install-record.txt --single-vers
ion-externally-managed --prefix /tmp/pip-build-env-g4trlnq4/overlay --compile --install-headers /tmp/pip-build-env-g4trlnq4/overlay/include/python3.8/cffi Check the logs for full command output.
ERROR: Command errored out with exit status 1: /usr/bin/python3 /usr/lib/python3.8/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-g4trlnq4/overlay --no-warn-script-location --no-binary :none: --onl
y-binary :none: -i https://pypi.org/simple -- 'setuptools>=40.8.0' wheel 'cffi>=1.1; python_implementation != '"'"'PyPy'"'"'' Check the logs for full command output.
