It’s a set_value command to number helper. msg.payload is already what looks like a number (using a change node as it was originally in payload.payload.temperature.temperature . I know already i must be missing something but I can’t figure out what and I’m away from a big screen now. Is there a way to look at the code without a big screen ?
Is that possible without resorting to a function node and coding it? I’ve been trying to keep it simple and just use nodes but I think I should just have bitten the bullet early on and coded it. Probably would have saved time, although would have been harder to share with others.
It is in the node that complains a out a missing value.
You just need to insert that and correct the msg. text to where you have your value, like msg.payload maybe
