Error message I'm stumped
I’m new to using Node-Red, and I’m still finding my way through the basics,
This error continues to appear and fills my debug pane - :
28 May 08:50:37 - [error] [server:Home Assistant] Home assistant connection failed with error: Connection to home assistant could not be established with config: https://hassio.io:8123
I suspect it may be a configuration / installation issue, but I can’t cure it!
Can anyone help me?
Hi @Peter_Bradbury
I’m getting same error, maybe it’s a coincidence, but started after moving from 0.69.1 to 0.70 Hassio.
There is now a specific sub category for Node-Red, probably you should move this thread there, it’s under Third party Integrations -> Node-Red
You are supposed to be connecting to your local install, not hassio.io (Unless you own that domain?)
Thanks, for pointing that out. I must have left that in when I was failing to get duckdns to work.
Now removed and the error of course, is gone.
