Hi.
I´m running Home Assistant OS 5.12: core-2021.3.4 on a windows VM server.
I have about 30 shelly devices and they are configured through ha shelly core integration.
Mostly everything works but sometimes when I´m turning on or off one of my shelly 2.5 it doesnt respond and gives me an error in the log. If I try to turn on/off a second time it works.
What does the error message mean?
2021-03-18 20:47:22 ERROR (MainThread) [homeassistant.core] Error executing service: <ServiceCall light.turn_on (c:ce747467df9b0b1967f8f460dfbc772d): entity_id=['light.simsen'], params=>
File "/usr/src/homeassistant/homeassistant/core.py", line 1504, in catch_exceptions
await coro_or_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1523, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 642, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 681, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 679, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 235, in async_handle_light_on_service
await light.async_turn_on(**params)
File "/usr/src/homeassistant/homeassistant/components/shelly/light.py", line 184, in async_turn_on
self.control_result = await self.block.set_state(turn="on")
File "/usr/local/lib/python3.8/site-packages/aioshelly/__init__.py", line 452, in set_state
return await self.device.http_request(
File "/usr/local/lib/python3.8/site-packages/aioshelly/__init__.py", line 316, in http_request
resp = await self.aiohttp_session.request(
File "/usr/local/lib/python3.8/site-packages/aiohttp/client.py", line 544, in _request
await resp.start(conn)
File "/usr/local/lib/python3.8/site-packages/aiohttp/client_reqrep.py", line 890, in start
message, payload = await self._protocol.read() # type: ignore
File "/usr/local/lib/python3.8/site-packages/aiohttp/streams.py", line 604, in read
await self._waiter
aiohttp.client_exceptions.ClientOSError: [Errno 104] Connection reset by peer
/Jerry
