Error message " Task exception was never retrieved"
I keep getting the following message in my log file, but I’m not sure what it relates to.
Could someone please give me a hand to determine what it means and how to stop it.
I’m not sure what his relates to, the only problem that I’m having right now is HA not properly parsing ONVIF commands from one CCTV camera, but I can’t see any firm connections between that and this to confirm that these are related .
Logger: homeassistant
Source: /usr/src/homeassistant/homeassistant/runner.py:145
First occurred: 13:44:55 (483 occurrences)
Last logged: 20:14:50
Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.11/site-packages/httpcore/_exceptions.py", line 10, in map_exceptions
    yield
  File "/usr/local/lib/python3.11/site-packages/httpcore/_backends/anyio.py", line 34, in read
    return await self._stream.receive(max_bytes=max_bytes)
  File "/usr/local/lib/python3.11/site-packages/anyio/_backends/_asyncio.py", line 1104, in receive
    raise self._protocol.exception from None
anyio.BrokenResourceError
  File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 67, in map_httpcore_exceptions
    yield
  File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 371, in handle_async_request
    resp = await self._pool.handle_async_request(req)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection_pool.py", line 268, in handle_async_request
    raise exc
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection_pool.py", line 251, in handle_async_request
    response = await connection.handle_async_request(request)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/connection.py", line 103, in handle_async_request
    return await self._connection.handle_async_request(request)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 133, in handle_async_request
    raise exc
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 111, in handle_async_request
    ) = await self._receive_response_headers(**kwargs)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 176, in _receive_response_headers
    event = await self._receive_event(timeout=timeout)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_async/http11.py", line 212, in _receive_event
    data = await self._network_stream.read(
  File "/usr/local/lib/python3.11/site-packages/httpcore/_backends/anyio.py", line 31, in read
    with map_exceptions(exc_map):
  File "/usr/local/lib/python3.11/contextlib.py", line 155, in __exit__
    self.gen.throw(typ, value, traceback)
  File "/usr/local/lib/python3.11/site-packages/httpcore/_exceptions.py", line 14, in map_exceptions
    raise to_exc(exc) from exc
httpcore.ReadError
  File "/usr/local/lib/python3.11/site-packages/onvif/managers.py", line 189, in _renew_or_restart_subscription
    await self._renew_subscription() or await self._restart_subscription()
  File "/usr/local/lib/python3.11/site-packages/onvif/managers.py", line 154, in _restart_subscription
    return await self._start()
  File "/usr/local/lib/python3.11/site-packages/onvif/managers.py", line 256, in _start
    result = await self._subscription.Renew(
  File "/usr/local/lib/python3.11/site-packages/zeep/proxy.py", line 64, in __call__
    return await self._proxy._binding.send_async(
  File "/usr/local/lib/python3.11/site-packages/zeep/wsdl/bindings/soap.py", line 156, in send_async
    response = await client.transport.post_xml(
  File "/usr/local/lib/python3.11/site-packages/zeep/transports.py", line 235, in post_xml
    response = await self.post(address, message, headers)
  File "/usr/local/lib/python3.11/site-packages/zeep/transports.py", line 220, in post
    response = await self.client.post(
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1877, in post
    return await self.request(
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1559, in request
    return await self.send(request, auth=auth, follow_redirects=follow_redirects)
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1646, in send
    response = await self._send_handling_auth(
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1674, in _send_handling_auth
    response = await self._send_handling_redirects(
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1711, in _send_handling_redirects
    response = await self._send_single_request(request)
  File "/usr/local/lib/python3.11/site-packages/httpx/_client.py", line 1748, in _send_single_request
    response = await transport.handle_async_request(request)
  File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 370, in handle_async_request
    with map_httpcore_exceptions():
  File "/usr/local/lib/python3.11/site-packages/httpx/_transports/default.py", line 84, in map_httpcore_exceptions
    raise mapped_exc(message) from exc
httpx.ReadError
