Error message when creating light counter
I’m really new to home assistant and I’m trying to use templates to create a counter to display how many lights are currently turned on. Here is what I’ve tried:
platform: template
  sensors:
  current_lights_on:
  friendly_name: Current lights on
  unit_of_measurement: 'on'
  value_template: >
  {% set lights = [ states.light.lamp, states.light.light_strip,
  states.light.patio, ] %}  {{ lights | selectattr('state','eq','on') | list |
  count }}
It keeps returning the error message “Error loading /config/configuration.yaml: mapping values are not allowed here in “/config/configuration.yaml”, line 20, column 10”
Any help would be greatly appreciated. Thankyou so much!
  sensors:
    current_lights_on:
      value_template: >
        {% set lights = [ states.light.lamp, states.light.light_strip, states.light.patio, ] %}
        {{ lights | selectattr('state','eq','on') | list | count }}
There’s an example here https://www.home-assistant.io/integrations/template/#legacy-sensor-configuration-format
Note however that you should not be using the legacy format for new sensors. Use the new format.
configuration.yaml
template:
  - sensor:
      - name: Current lights on
        state: >
Hey man, thanks so much for the reply!
I tried the new format code you sent through and got the following error message: Error loading /config/configuration.yaml: while scanning a simple key in “/config/configuration.yaml”, line 19, column 1 could not find expected ‘:’ in “/config/configuration.yaml”, line 20, column 11
Not sure what I’m doing wrong?
Typo. Sorry. This
Should be
template:
That works now! Thanks again mate.
