When reloading climate under yaml I get the message "Integration ‘b’ not found ", and it shows that the climate component fails to load. Then the average sensor also stops working. When reloading al other options I don’t get an error so it must be related to the climate yaml. When i do a reboot of the system everything seems to work (also the average sensor) and there is no error message in the logs.
The check configuration option shows everything green. Tried to disable my climate integrations but error persist.
Complete error message is:
Logger: homeassistant.components.websocket_api.http.connection
Source: loader.py:825
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 9:40:10 AM (12 occurrences)
Last logged: 10:01:49 AM
[140491804038224] Integration 'b' not found.
[140491804038224] Integration 'd' not found.
[140492270485616] Integration 'b' not found.
[140491801086992] Integration 'b' not found.
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 199, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1820, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1857, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 874, in admin_handler
await result
File "/usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py", line 337, in async_handle_reload_all
await asyncio.gather(*tasks)
task.result()
await result
File "/usr/src/homeassistant/homeassistant/helpers/reload.py", line 176, in _reload_config
await async_reload_integration_platforms(hass, domain, platforms)
File "/usr/src/homeassistant/homeassistant/helpers/reload.py", line 53, in async_reload_integration_platforms
File "/usr/src/homeassistant/homeassistant/helpers/reload.py", line 63, in _resetup_platform
integration = await async_get_integration(hass, integration_platform)
File "/usr/src/homeassistant/homeassistant/loader.py", line 825, in async_get_integration
raise int_or_exc
homeassistant.loader.IntegrationNotFound: Integration 'b' not found.
Does anybody have a clue what might be wrong ?
