Error Messages in logfile
I get this errors. And I´m searching a long time…
  • Invalid config for [template]: [name] is an invalid option for [template]. Check: template->name. (See /config/configuration.yaml, line 55).
  • Invalid config for [template]: [sensor] is an invalid option for [template]. Check: template->sensor->0->sensor. (See /config/configuration.yaml, line 62).
  • Invalid config for [template]: [utility_meter] is an invalid option for [template]. Check: template->utility_meter. (See /config/configuration.yaml, line 67).
  • Invalid config for [template]: [name] is an invalid option for [template]. Check: template->name. (See /config/configuration.yaml, line 81).
  • Invalid config for [template]: [sensor] is an invalid option for [template]. Check: template->sensor->1->sensor. (See /config/configuration.yaml, line 54).
My configuration.yaml
# THEMES
frontend:
  themes: !include_dir_merge_named themes
# Loads default set of integrations. Do not remove.
default_config:
# Text to speech
tts:
  - platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
############## Helium include ############################
###### ergänzt für Nachrichten an App
mobile_app:
             - service: notify.mobile_app_iPhone von Alwin (3291))
               title: "TV wurde angeschaltet"
               message: "Fernseher wurde angeschaltet"
######################### VU Integration ###############################
media_player: !include vuplus.yaml
#            - platform: enigma2
#              host: 192.168.10.99
#              name: VU+ Wohn
#              use_channel_icon: true
#              host: 192.168.10.60
#              name: VU+ Schlaf
############ Example configuration.yaml entry WOL VU Schlaf #############
switch:
      - platform: wake_on_lan
        mac: 00:1D:EC:06:A9:30
# Wetterwarnung Deutscher Wetterdienst
#sensor:
#  - platform: dwd_weather_warnings
# region_name: Wetterwrnung Moormerland
#    region_name: 803457014
#################### TEMPLATE BEREICH ###############################
## Solar-Log
template:
        - name: "Solarlog yield day"
          state: "{{ (states('sensor.solarlog_yield_day') | float(default=0) * 1000) | round(0,default=0) }}"
########## Hier werden Shelly 3em gesamtsensoren eingebunden ################
        - sensor:
                   !include shelly3em.yaml
        - utility_meter:
                   !include utility_meter.yaml
############### Tesla Energy Dashboard ###############
# Calculate the power used by the home from known values of solar generation, battery charge/discharge, and grid demand
        - name: "Home Power"
          unit_of_measurement: 'W'
          device_class: 'power'
          state_class: 'measurement'
          state: >-
             {% set power = ((states('sensor.power_import')|int) + (states('sensor.solarlog_garage_power_ac')|int)) + (states('sensor.STP10.0-3SE-40 562 OST grid_power')|int)) - (states('sensor.power_export')|int) + states('sensor.simulated_power_battery')|int(default=0) %}
             {% if power > 0 %}
               {{ power }}
             {% else -%}
               0
             {% endif %}
####### TEMPLATE BEREICH ENDE #########################################
#################### Modbus WR SMA Tripower einbinden #################
modbus: !include modbus.yaml
#        sensors:
#           - name: PV_Gesamtertrag
#             unit_of_measurement: kWh
#             slave: 3
#             address: 30531
#             input_type: input
#             count: 2
#             device_class: energy
#             state_class: total_increasing
#           - name: PV_Leistung
#             unit_of_measurement: W
#             slave: 3
#             address: 30775
#             input_type: input
#             count: 2
#             device_class: power
#             state_class: measurement
#           - name: PV_Tagesertrag
#             unit_of_measurement: Wh
#             slave: 3
#             address: 30517
#             count: 4
#             input_type: input #data_type: int
# ENDe Der Sektion VOR CHATGPT
notify:
       - name: "Homeassistant_Email"
         platform: smtp
         server: "mail.gmx.net"    #smtp
         sender: "[email protected]"
         recipient: # "[email protected]"
                  - "[email protected]"
         username: "[email protected]"#         password: "xxxxxxx"
         encryption: starttls
####### waste_collection_schedule source configuration
waste_collection_schedule:
  sources:
    - name: jumomind_de
      args:
        service_id: mymuell
        city_id: 71133
        area_id: 760
  # ------- Garbage Collection -------
  # Nächste Abholung
  - platform: waste_collection_schedule
    name: "Nächste Abholung"
    value_template: '{{value.types|join(", ")}}{% if value.daysTo == 0 %} Heute{% elif value.daysTo == 1 %} Morgen{% else %} in {{value.daysTo}} Tagen{% endif %}'
  # Nächste Restmüll-Abholung
    types:
       - Hausmüll
#      - Restmüll
  # Nächste Biomüll Abholung
    types:
      - Bio Müll
  # Nächste gelber-Sack Abholung
    types:
      - Gelber Sack
  # Nächste Papiermüll Abholung
    types:
      - Blaue Tonne
Thanxs
Indentation doesn’t look right. Shouldn’t it be something like:
template:
  - sensor:
