ERROR: Moving Media Folder on Home Assistant 2023.3.6 Supervisor 2023.03.3 on Debian 11
Hi, new to HA coming from Domoticz. Did a bare metal Debian install and then installed HA (supervisor) as per documentation on i5 Gen 8 system.
HA Not showing any supported errors etc. Frigate is installed as Add-on.
The HA media folder is located at /usr/share/hassio/media which is on an internal ssd.
Frigate requires a lot of storage for video recordings, therefore, I would like to move /media to another internal drive which is installed the machine. The larger drive is unmounted.
At system/storage/…/move_disk I can select the target disk. After selecting move i get:
“Move disk Failed
‘DataDisk.migrate_disk’ blocked from execution, no Home Assistant OS available”
would appreciate any help in fixing this and/or achieving my goal of moving /frigate folder from media to another local drive. Have tried symlinking frigate to external drive but Frigate will not start…
b
Found a work around that works: removing Media folder and replacing with a folder mounted to the other drive:
