Hi guys, I am trying to boot home assistant in Raspberry PI 4 from a SSD. I installed raspbian in the SD, I followed the steps in these posts - post 2 and got the same result after executing the vcgencmd bootloader_vertion and bootloader_config. The diference is that I am not using the same rabian in the SSD, I installed the Home Assitant img in it but when I remove the ssd and power up the rasberrypi only with the ssd, it doesn’t boot and gets an error.
Part of the error:
bootloader: 23a9f59b May 15 2020
boot: mode USB-MSD (4) order 00000f41 retry 0/1
SD: card not detected
fw: start4.elf fixup4.dat
recovery.elf not found (6)
start4.elf is not compatible
ERROR: 00000044
