any idea about these errors:
2018-11-03 09:49:08 ERROR (MainThread) [homeassistant.components.climate] Error while setting up platform netatmo Traceback (most recent call last): File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform SLOW_SETUP_MAX_WAIT, loop=hass.loop) File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for return fut.result() File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result raise self._exception File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/climate/netatmo.py", line 50, in setup_platform for module_name in data.get_module_names(): File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/climate/netatmo.py", line 164, in get_module_names for module in self.thermostatdata.modules[self.device].values(): KeyError: 'salon' 2018-11-03 09:49:08 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform netatmo Traceback (most recent call last): File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform SLOW_SETUP_MAX_WAIT, loop=hass.loop) File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for return fut.result() File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result raise self._exception File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/netatmo.py", line 80, in setup_platform if module_name not in data.get_module_names(): File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/netatmo.py", line 304, in get_module_names self.update() File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/sensor/netatmo.py", line 333, in update for module in self.data: TypeError: 'NoneType' object is not iterable 2018-11-03 09:49:08 ERROR (MainThread) [homeassistant.components.binary_sensor] Error while setting up platform netatmo Traceback (most recent call last): File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform SLOW_SETUP_MAX_WAIT, loop=hass.loop) File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for return fut.result() File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result raise self._exception File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/binary_sensor/netatmo.py", line 73, in setup_platform if not data.get_camera_names(): File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/netatmo.py", line 82, in get_camera_names self.update() File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/util/__init__.py", line 324, in wrapper result = method(*args, **kwargs) File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/netatmo.py", line 113, in update self.camera_data = pyatmo.CameraData(self.auth, size=100) File "/srv/homeassistant/lib/python3.5/site-packages/smart_home/Camera.py", line 79, in __init__ self.default_camera = list(self.cameras[self.default_home].values())[0] AttributeError: 'CameraData' object has no attribute 'default_home' 2018-11-03 09:49:11 ERROR (MainThread) [homeassistant.components.camera] Error while setting up platform netatmo Traceback (most recent call last): File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform SLOW_SETUP_MAX_WAIT, loop=hass.loop) File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for return fut.result() File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result raise self._exception File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run result = self.fn(*self.args, **self.kwargs) File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/camera/netatmo.py", line 40, in setup_platform for camera_name in data.get_camera_names(): File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/netatmo.py", line 82, in get_camera_names self.update() File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/util/__init__.py", line 324, in wrapper result = method(*args, **kwargs) File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/netatmo.py", line 113, in update self.camera_data = pyatmo.CameraData(self.auth, size=100) File "/srv/homeassistant/lib/python3.5/site-packages/smart_home/Camera.py", line 79, in __init__ self.default_camera = list(self.cameras[self.default_home].values())[0] AttributeError: 'CameraData' object has no attribute 'default_home'
i have this setup into configuration.yaml
`netatmo:
api_key: 58***********6
secret_key: 11****************X
username: [email protected]
password: password
climate:
platform: netatmo
relay: salon
thermostat:
- Salon `` - platform: netatmo
station: Alcortwo Weather
modules:
indoor salon: - temperature
- co2
- pressure
- noise
- humidity
- wifi_status
alcortwo outside: - temperature
- humidity
- battery_vp
- platform: yr
- platform: time_date
display_options:- ‘time’
- ‘date’`
