Error no access to home-assistant.log in homeassistant.bootstrap
hi,
Lately ive been receiving this error about the error.log when doing hassio ha check before restarting"
core-ssh:~# hassio ha check
    "result": "error",
    "message": "starting version 3.2.4\nTesting configuration at /config\n2018-01-23 12:31:50 ERROR (MainThread) [homeassistant.bootstrap] Unable to setup error log /config/home-assistant.log (access denied)\n2018-01-23 12:31:59 ERROR (SyncWorker_0) [homeassistant.util.yaml] mapping values are not allowed here\n  in \"/config/lights.yaml\", line 31, column 9\n2018-01-23 12:31:59 ERROR (MainThread) [homeassistant.bootstrap] Error loading /config/configuration.yaml: mapping values are not allowed here\n  in \"/config/lights.yaml\", line 31, column 9\n"
Though the lights.yaml error is obvious to me, the setup error on the logfile isnt. Why can’t it get access to the home-assistant.log?
Cheers,
Marius
I’ve got the same after restarting via dashboard.
I even deleted the log, thinking that hass.io will make a new one - but with no luck.
I didn’t restart my RPi yet, I’m afraid that it won’t start…
It would be cool to know what’s happening… [FYI: I tried to add new sensors, but after getting this error I’ve deleted them but error persists…]
in the latest versions of HA i see this error if and only theres an error in a configuration file, which is reported after the log-error.
Solve the configuration file, and the log-error is gone.
Seems to be a non critical but confusing error…?
Marius
hm, it dissapeared today morning without me making any change in the configuration…
confusing indeed, I don’t like errors, but if only can see in the log what’s up - it’s cool. worst thing there is if the log can’t be written, or the error is totally random without any logical clue…
