Attempting to install Hassio on a raspberry pi 2, flashed SD Card with image, configured network settings etc.
The “Preparing Hassio (this can take up to 20 minutes)” was displayed for hours, left it overnight - was still preparing in the morning.
Checked the supervisor service log files (as detailed here: https://home-assistant.io/developers/hassio/debugging/ )
Log file shows the following error:
"hassio start-resin-supervisor[1075]: 17-12-10 11:37:07 ERROR (SyncWorker_9) [hassio.dock.interface] Can’t install homeassistant/raspberrypi2-homeassistant:0.59.2 -> 404 Client Error: Not Found (“no such image: homeassistant/raspberrypi2-homeassistant:0.59.2: No such image: homeassistant/raspberrypi2-homeassistant:0.59.2”).
Anyone else seeing this?
