Hi, trying to get Home Assistant running on my Synology D1815+, running DSM 6.1.3-15152. I’ve been following instructions here: https://home-assistant.io/getting-started/installation-synology/ and Error starting Home Assistant on Synology for first time, but I have error:
017-12-19 00:52:53 ERROR (Thread-8) [homeassistant.util.package] Unable to install package warrant==0.6.1: Command “/volume1/@appstore/py3k/usr/local/bin/python3 -u -c “import setuptools, tokenize;
file_=’/tmp/pip-build-by7b83ox/pycryptodome/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --reco
rd /tmp/pip-qnvfx01b-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=” failed with error code 1 in /tmp/pip-build-by7b83ox/pycryptodome/
2017-12-19 00:52:53 ERROR (MainThread) [homeassistant.setup] Not initializing cloud because could not install dependency warrant==0.6.1
2017-12-19 00:52:53 ERROR (MainThread) [homeassistant.setup] Setup failed for cloud: Could not install all requirements.
2017-12-19 00:52:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service_call_id=140191829972192-2, service=create, service_data=message
=The following components and platforms could not be set up:
- cloud
Please check your config., notification_id=invalid_config, title=Invalid config>
2017-12-19 00:52:53 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service_call_id=140191829972192-3, service=create, service_data=message
- [cloud] .
