I get last time error notification in HA as below, what is the problem?
Login attempt or request with invalid authentication from core-nginx-proxy.local.hass.io
I am using the DuckDNS and nginx proxy.
Someone tried to access Home Assistant with the wrong credentials.
Are there on HA any log where i can see from which IP that is?
Yes, by adding the following to configuration.yaml
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.19.0.7
Where 172.19.0.7 is the IP of the container running NGINX. I assume you’d need to put 127.0.0.1 there as you are using the add-on on the same machine as Home Assistant, but I’m not sure.
You also need the following line in the NGINX config to forward the headers
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
Currently it will always show the address of the NGINX proxy server.
Where do i really put in the config of NGINX Home Assistant SSL proxy addon?
NGINX is installed via Home asssitant addons, just it is on the same machine. Do i need to put 127.0.0.1 ?
In the location part, here’s my full config for the location part
location / {
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_pass http://ip-of-ha-instance:8123;
I would say so,you need to try.
I think i have another sort of addon
my config is now as below but when i put the location at the end Home assistant say invalid config.
domain: mydomain.com
certfile: fullchain.pem
keyfile: privkey.pem
hsts: max-age=31536000; includeSubDomains
cloudflare: false
customize:
active: false
default: nginx_proxy_default*.conf
servers: nginx_proxy/*.conf
I don’t run any add-on, I run it as a docker container.
Do you have any files like nginx_proxy....conf
in the /share
directory of your Home Assistant configuration? From the docs of this addon it looks like the config files should be stored there.
Checked that but no any files related configs or something like that.
I’m sorry, I don’t know how it works with the add-on. I assume you can put a file called nginx_proxy_default.conf in there and add the configuration. But I’m just guessing. This is my full config file as a reference:
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
# redirect all traffic to https
server {
listen 80;
server_name *.yourdomain.com;
return 301 https://$host$request_uri;
############### Home Assistant ####################
server {
listen 443 ssl default_server;
server_name ha.yourdomain.com;
# enable subfolder method reverse proxy confs
include /config/nginx/proxy-confs/*.subfolder.conf;
# all ssl related config moved to ssl.conf
include /config/nginx/ssl.conf;
proxy_buffering off;
location / {
# enable subdomain method reverse proxy confs
include /config/nginx/proxy-confs/*.subdomain.conf;
# enable proxy cache for auth
proxy_cache_path cache/ keys_zone=auth_cache:10m;
