Error on HACS with Renaut Zoe
since a couple of days I get an error in the log file, saying something about a Renaut custom compent in the HACS which makes some troubles (see below). So I do NOT have any such
integration, nor never installed an integration for a Renault. What could be the root cause and how to stop this? Any ideas? Thank you.
error message i see in log file:
hacf-fr/hassRenaultZE - GitHub returned 404 for https://api.github.com/repos/hacf-fr/hassRenaultZE
I got the same error. The reason is because the Github repo of the app has been removed. Currently this is not detected by HACS, so it triggers an error.
Yes, I assumed it would be so. I just don’t understand why HACS is set up like this and shows component errors that have never been installed on my system. It is confusing.
Same issue here.
Same here.
Yes but the repo is now up again, and HACS continue to set it in blacklist.
Is there something we can do to let HACS know this ??
Same here!
Hi all,
Are you still having issues accessing the GitHub? https://api.github.com/repos/hacf-fr/hassRenaultZE
It seems that @ludeeus has removed the repository, even though it is definitely still maintained!
It seems that GitHub mistakenly deactivated the hacf-fr account earlier this week.
A new PR has been created on HACS to reactivate it: https://github.com/hacs/default/pull/860
HACS is still playing up. I removed the repository using HACS and re-added it manually (3.07). The integration continues to work without needing to change the configuration but it would be good to get the update notifications back.
Yes, but that’s now out of my hands.
We are all waiting on @ludeeus to re-integrate it into HACS.
HACS has just merged the reversal PR (https://github.com/hacs/default/pull/860)
So it should all be ok now.
