I just received my Argon one for my raspberry pi 4
I would like to help and test your addon.
The problem is each time I uncomment the line “dtparam=i2c_arm=on” to get i2c, the pi doesn’t boot anymore. I was using this method I2c not working on the Pi4
big thank you to @Misiu for the custom component!! I manage to get it working. Biggest difficulty for me was to enable l2c as the partition for hass overlay did not show up when i plug in into my PC so i couldnt change the file and ended up having to load up Linux to do it
For everyone having trouble with I2C/1wire - I’ve created a feature request Allow enabling I2C and 1wire via Home Assistant CLI.
Please upvote it
Enabling both interfaces should be much easier and properly documented.
Your Argon40 component works great. I threw together an automation for HA to regulate the fan speed in discrete steps based on CPU temp which seems to be working smoothly.
Do you think you could add compatibility for the power button? It would be nice if it showed up as a sort of momentary switch in HA to be used in automations. To be honest, I’m not entirely sure what I would do with it, but because it’s on the Argon case it would be nice to have for use in HA.
I’ve tried that guide on a fresh installed HassOS (4.10) and I failed.
I’m using Windows to create those files, so maybe that was the problem? I’ve tried saving files as ANSI and as UTF8, I’ve changed new line character from CR LF to LF (Unix style) and I had no luck
When I think about that, the only thing I didn’t try was to use another USB stick.
What USB port did you use? 2.0 or 3.0?
Do you remember if something should show in the logs saying the import was successful? (it should show something)
you can always create a PR to my repo with your automation, or post it here and I’ll update the readme
I think you can use the power button already.
Argon one script is using pin 4 with pull down:
looking too for support about this case fan control capabilities. I installed your repo and enabled i2c, bit can’t find the argon40.set_fan_speed service in home assistant. What went wrong?
Hi, I was looking at the button too, had seen the argon script and already tried the binary sensor for pin 4, but for me it doesnt work, no response. invert_logic: true just makes the sensor appear always on in stead of always off… Wondering whether this does work for others?
the problem is RPI.GPIO isn’ that good at reading updates of GPIO.
I’ll try to write something, but not sure if I’ll be able to change anything (I’m also planning to use PRI.GPIO). I think gpiozero could be better, but can’t tell without trying
The worst part is enabling I2C, the rest is easy.
If you have the new case then you will be able to enable the always-on feature (using set-mode service)
The next step is the config flow. I’m working on this right now.
Double-tap also confirm working, the fan is actually quite noisy no matter what speed you set. Very difficult to notice the difference sound between fan speeds, but you could feel the difference in the amount of air that comes out of the case. Since it’s pretty noisy, I’ve set the fan to switch off below 45 deg Celcius.
The double-tap sure makes things a little bit more convenient:
