Error on Spotify config file
Hi, I searched in the forum and i cannot find the correct syntax. This is my configuration.yaml file:
media_player:
  - platform: spotify
    client_id: XXXXX
    client_secret: YYYYYY
  - service: media_player.select_source
      entity_id: media_player.spotify
      source: "clazio"
  - service: media_player.play_media
      media_content_type: playlist
      media_content_id: spotify:user:TTTTTT:playlist:ZZZZZZZZZZZ
and I have errors when checking the configuration.
I tried without the data:
If I only use this code:
media_player:
  - platform: spotify
    client_id: XXXXX
it works perfectly but I would like to have playlists.
Any clue on where is the problem ?
Thanks for your help
Your problem is is that this stuff…
  • service: media_player.select_source
    source: “clazio”
  • service: media_player.play_media
you do via an automation, you can’t add it to the configuration.
OK, thanks, I will try it.
