Error on Spotify
Hi there,
I’m having issues connecting to my Spotify account. I’m getting the following error:
Sun May 05 2019 18:14:27 GMT-0300 (Horário Padrão de Brasília)
spotify: Error on device update!
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 159, in _new_conn
    (self._dns_host, self.port), self.timeout, **extra_kw)
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/connection.py", line 57, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/local/lib/python3.7/socket.py", line 748, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 600, in urlopen
    chunked=chunked)
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 343, in _make_request
    self._validate_conn(conn)
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 839, in _validate_conn
    conn.connect()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 301, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.7/site-packages/urllib3/connection.py", line 168, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
urllib3.exceptions.NewConnectionError: <urllib3.connection.VerifiedHTTPSConnection object at 0x7fafdd6db630>: Failed to establish a new connection: [Errno -3] Try again
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 449, in send
    timeout=timeout
  File "/usr/local/lib/python3.7/site-packages/urllib3/connectionpool.py", line 638, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/local/lib/python3.7/site-packages/urllib3/util/retry.py", line 399, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.spotify.com', port=443): Max retries exceeded with url: /v1/me/ (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fafdd6db630>: Failed to establish a new connection: [Errno -3] Try again'))
  File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 377, in async_device_update
    await self.hass.async_add_executor_job(self.update)
  File "/usr/local/lib/python3.7/site-packages/homeassistant/components/spotify/media_player.py", line 161, in update
    self.refresh_spotify_instance()
  File "/usr/local/lib/python3.7/site-packages/homeassistant/components/spotify/media_player.py", line 157, in refresh_spotify_instance
    self._user = self._player.me()
  File "/usr/local/lib/python3.7/site-packages/spotipy/client.py", line 568, in me
    return self._get('me/')
  File "/usr/local/lib/python3.7/site-packages/spotipy/client.py", line 148, in _get
    return self._internal_call('GET', url, payload, kwargs)
  File "/usr/local/lib/python3.7/site-packages/spotipy/client.py", line 110, in _internal_call
    r = self._session.request(method, url, headers=headers, proxies=self.proxies, **args)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 533, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/sessions.py", line 646, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/requests/adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='api.spotify.com', port=443): Max retries exceeded with url: /v1/me/ (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7fafdd6db630>: Failed to establish a new connection: [Errno -3] Try again'))
Already tried deleting the spotify token cache file and restarting the authorization process, but had no luck up to this point.
Any clue as to what may be happening would be greatly appreciated.
Errno -3 is a temporary failure in name resolution (The hostname can’t be looked up).
Assuming the hostname is correct, depending on your environment, it might be easier to reboot than to flush your DNS cache.
