Error on startup
This is HomeAssistant on Docker on Ubuntu 20.04
It has been running fine, but latest update to 2021.3.0.
Now it takes 5-10 minutes to come up, and then shows errors, but runs fine it seems.
I see these errors in log:
2021-03-09 18:04:15 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly.
2021-03-09 18:04:25 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2021-03-09 18:05:15 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: recorder
2021-03-09 18:05:39 WARNING (Recorder) [homeassistant.components.recorder.migration] Database is about to upgrade. Schema version: 9
2021-03-09 18:05:39 WARNING (Recorder) [homeassistant.components.recorder.migration] Adding index ix_states_old_state_id to database. Note: this can take several minutes on large databases and slow computers. Please be patient!
2021-03-09 18:05:52 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (sqlite3.DatabaseError) database disk image is malformed
[SQL: CREATE INDEX ix_states_old_state_id ON states (old_state_id)]
(Background on this error at: Error Messages — SQLAlchemy 1.3 Documentation)
2021-03-09 18:05:52 ERROR (Recorder) [homeassistant.components.recorder] Error during connection setup to sqlite:////config/home-assistant_v2.db: (sqlite3.DatabaseError) database disk image is malformed
Here is configuration.yaml:
`mythuser@amethi:~/homeassistant$ cat configuration.yaml
Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: example.duckdns.org:8123
Text to speech
tts:
  • platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
panel_custom:
  • name: zwave-graph-panel
    url_path: zwave-graph
    sidebar_title: Z-Wave Graph
    sidebar_icon: mdi:z-wave
    module_url: /local/zwavegraph3.js
    config:
    ranker - pick one: network-simplex, tight-tree, longest-path
    ranker: network-simplex
    edge_visibility - pick one: relevant, all
    edge_visibility: relevant
    grouping - pick one: z-wave, ungrouped
    grouping: z-wave
Example configuration.yaml entry
logbook:
Basic configuration.yaml entry
history:
Your database is toast (not unheard of in terms of sqllite).
A simple fix is to shutdown HA, delete the database (//config/home-assistant_v2.db), then restart HA. You’ll lose all your history though.
A more complicated fix would be to shutdown HA, copy the database file to your local computer and then use a db tool for sqllite databases (there are tons out there for nearly every operating system) and try to do a repair on it and then copy it back to your HA instance. Then, restart HA. There’s no guarantee this will work however.
I would strongly recommend that you change from using Recorder with sqllite and instead move to a better database engine like Mysql or MariaDB.
Thank you very helpful. I will delete the database. Nothing there I need. I do have Mysql running on this machine not in docker, being used for mythtv. Would there be any issues using it also for homeassistant, and can this be done outside docker?
Nope. Just follow the instructions here: Recorder - Home Assistant
Basically, create a database in MySql along with a user. Mine is named ha_logger. Make sure to set the permissions so that the new user only has access to that database and nothing else. Then, change the recorder: entry in your configuration.yaml and you should be good to go!
:slight_smile:
How would that work if you have the default setup, with docker…?
Because I get this;
rm: cannot remove ‘//config/home-assistant_v2.db’: No such file or directory
Thank you, deleting the home-assistant_v2.db worked perfect.
