Hello to all, I started facing this issue after a renew of the domain (keep the exactly same address) , I’m using the cloudflare addon in order to access remotely to the home assistant. And this issue only occurs on the mobile app. Can someone please help me in order to solve this issue? Thank in advance!
Information available on the addon log
This certificate expires on 2025-03-17.
These files will be updated when the certificate renews.
on the popup click on settings, go to troubleshooting and look at the logs which will contain the failure to fix
you may need to import a CA based on the error
Thank you Its solved now
