I have been chasing a bug for a while and have narrowed it down to this piece of code. Both entity_light and entity_sensor_brightness are variables where I pass in a light and a sensor entity respectively.
What am I doing wrong? This code causes the following error:
Invalid config for [automation]: not a valid value for dictionary value @ data[‘action’][17][‘entity_id’]. Got None. (See /config/configuration.yaml, line 254).
2:59:20 PM – config.py (ERROR) - message first occurred at 2:36:37 PM and shows up 3 times
main_floor_light_binary_set:
alias: "Main floor light binary set"
sequence:
- service: >
{% if states(entity_sensor_brightness) > 0 %}
light.turn_on
{% else %}
light.turn_off
{% endif %}
entity_id: "{{ entity_light }}"
Thanks much for your help!
Your error message refers to an automation, but the code you’ve posted is a script.
Sorry not sure how that got there, here is the actual error:
2021-01-02 17:36:57 ERROR (MainThread) [homeassistant.config] Invalid config for [script]: not a valid value for dictionary value @ data[‘sequence’][0][‘entity_id’]. Got None. (See /config/configuration.yaml, line 255).
Yup, still going to need to see an automation. Specifically the automation that calls this script and passes it the variables.
Thanks. This script is called by another script. Note that if i comment out the above script - I do not get an error at start up - i will get an error when the below script cannot find the above script. However, if i include the script in my first post - i get the error right at start-up and also a notification that ‘script’ platform failed to load. Thanks a lot for your help!
main_floor_dynamic_light_adjust:
alias: 'Main floor dynamic light adjust'
sequence:
- condition: template
value_template: "{{ not is_state(entity_select_dynamic_mode, 'off') }}"
value_template: "{{ is_state(entity_occupancy_sensor, 'on') }}"
- service: >
{% if is_state('entity_select_dynamic_mode', 'gradient') %}
script.main_floor_light_gradient_set
{% elif is_state('entity_select_dynamic_mode', 'binary') %}
script.main_floor_light_binary_set
{% else %}
script.main_floor_error_log
{% endif %}
entity_sensor_brightness: sensor.target_brightness_accent_lamp
entity_light: light.dining_room_table_lamp
And the script I just posted is called by an automation like this
- service: script.main_floor_dynamic_light_adjust
entity_select_dynamic_mode: input_select.front_foyer_pot_lights_dynamic_select
entity_occupancy_sensor: binary_sensor.main_floor_occupancy_med
entity_sensor_brightness: sensor.target_brightness_ambient_light
entity_light: light.front_foyer_pot_lights
Also, this other script I call from main_floor_dynamic_light_adjust does not throw an error
main_floor_light_gradient_set:
alias: "Main floor light gradient set"
sequence:
- service: light.turn_on
data_template:
brightness_pct: >
{{ states(entity_sensor_brightness)|int }}
This might have been it! I think the data_template missing below service caused it
sequence:
- service: >
light.turn_on
{% else %}
light.turn_off
{% endif %}
data_template:
Doesn’t need data_template (that’s deprecated), but it does need data. For some reason the templates don’t work with the shortcut.
Thanks! Didn’t know that - both that the data_template is deprecated and that templates don’t work with the shortcut. Fixed now.
