I am getting the following error preventing HAOS from restarting and can not track it down. Can I please get some assistance?
2024-12-04 13:41:21.469 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [139695443686832] Unexpected exception
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2802, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1110, in _async_admin_handler
await result
File "/usr/src/homeassistant/homeassistant/components/homeassistant/__init__.py", line 190, in async_handle_core_service
errors = await conf_util.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/config.py", line 1325, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File "/usr/src/homeassistant/homeassistant/helpers/check_config.py", line 300, in async_check_ha_config_file
p_validated = platform_schema(p_validated)
File "/usr/local/lib/python3.12/site-packages/voluptuous/validators.py", line 259, in __call__
return self._exec((Schema(val) for val in self.validators), v)
File "/usr/local/lib/python3.12/site-packages/voluptuous/validators.py", line 382, in _exec
v = func(v)
File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 205, in __call__
return self._compiled([], data)
File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 779, in validate_callable
return schema(data)
File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 549, in validate_dict
return base_validate(path, data.items(), out)
File "/usr/local/lib/python3.12/site-packages/voluptuous/schema_builder.py", line 330, in validate_mapping
cval = cvalue(key_path, value)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 658, in verify
return cast(dict, schema(value))
File "/usr/local/lib/python3.12/site-packages/voluptuous/validators.py", line 256, in _run
return self._exec(self._compiled, value, path)
File "/usr/local/lib/python3.12/site-packages/voluptuous/validators.py", line 384, in _exec
v = func(path, v)
return schema(data)
File "/usr/src/homeassistant/homeassistant/helpers/config_validation.py", line 965, in validator
if key in config:
TypeError: argument of type 'NoneType' is not iterable
