Hi.
I’m having an issue when processing a webhook API request. I’m using Kerberos.io camera events (movement detection) to send a POST request to the API.
An example of the JSON payload is:
'regionCoordinates' : [618, 317, 703, 493],
'numberOfChanges' : 5446,
'timestamp' : '1465894497',
'microseconds' : '5-97451',
'token' : 695,
'pathToImage' : '1465894497_5-97451_frontdoor_618-317-703-493_5446_695.jpg',
'instanceName' : 'frontdoor'
The error I get is:
## Log Details (ERROR)
Log Details (ERROR)
Logger: homeassistant.components.webhook
Source: components/automation/webhook.py:30
Integration: Webhook (documentation, issues)
First occurred: 6:30:31 PM (1 occurrences)
Last logged: 6:30:31 PM
File "/usr/local/lib/python3.7/json/decoder.py", line 353, in raw_decode
obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Expecting property name enclosed in double quotes: line 2 column 3 (char 4)
So if I change the payload to:
"regionCoordinates" : [618, 317, 703, 493],
"numberOfChanges" : 5446,
"timestamp" : "1465894497",
"microseconds" : "5-97451",
"token" : 695,
"pathToImage" : "1465894497_5-97451_frontdoor_618-317-703-493_5446_695.jpg",
"instanceName" : "frontdoor"
The automation works just fine.
Any ideas?
