heinemannj
(Joerg Heinemann)
July 30, 2024, 12:24pm
1
I’ve recurring log errors but I have no idea how to fix.
Logger: homeassistant.helpers.sensor
Source: helpers/trigger_template_entity.py:209
First occurred: 13:00:00 (60 occurrences)
Last logged: 13:59:00
Error rendering state template for sensor.sg_ready_mode: TypeError: '>=' not supported between instances of 'str' and 'float'
- trigger:
- platform: time_pattern
minutes: "/1"
- variables:
t: "{{ now().isoformat() }}"
var: >-
{% from '032-emhass.jinja' import globalVariables %}
{{ globalVariables()|from_json }}
epexspot_quantile_forecast: "{{ states('sensor.epex_spot_data_net_quantile_forcast')|float(0) }}"
grid_power: "{{ states('sensor.power_meter_active_power')|float(0) }}"
EVU: "{{ states('switch.406_wp_sg_ready_evu') }}"
PV: "{{ states('switch.406_wp_sg_ready_pv_ma') }}"
- name: "sg-ready-mode"
unique_id: sg-ready-mode
state: >-
{% if EVU == 'on' and PV == 'off' %}
{{ 'EVU lock' }}
{% elif EVU == 'off' and PV == 'on' %}
{{ 'Recommendation' }}
{% elif EVU == 'on' and PV == 'on' %}
{{ 'Turn On' }}
{% else %}
{{ 'Normal' }}
{% endif %}
attributes:
mode: >-
{% if epexspot_quantile_forecast >= var.epexspot_quantile_setpoint_high
and grid_power <= 1000 %}
{{ 'EVU lock' }}
{% else %}
{{ 'Normal' }}
{% endif %}
evu_lock: "{{ EVU }}"
pv_ready: "{{ PV }}"
last_updated: "{{ t }}"
availability: >-
and states('switch.406_wp_sg_ready_pv_ma') }}
In template editor I can’t reproduce the error:
{% set var = globalVariables()|from_json %}
{% set t = now().isoformat() %}
{% set epexspot_quantile_forecast = states('sensor.epex_spot_data_net_quantile_forcast')|float(0) %}
{% set grid_power = states('sensor.power_meter_active_power')|float(0) %}
{% set EVU = states('switch.406_wp_sg_ready_evu') %}
{% set PV = states('switch.406_wp_sg_ready_pv_ma') %}
{{ 'EVU lock' }}
{{ 'Turn On' }}
{% else %}
{{ 'Normal' }}
{% endif %}
{{ 'EVU lock' }}
{% else %}
{{ 'Normal' }}
{% endif %}
{{ var }}
{{ var.epexspot_quantile_setpoint_high }}
{{ epexspot_quantile_forecast }}
{{ grid_power }}
{{ EVU }}
{{ PV }}
{{ t }}
Normal
Normal
{'inverter_rated_power': 6000.0, 'inverter_maximum_active_power': 6600.0, 'batteries_rated_capacity': 15.0, 'batteries_rated_charge_energy': 17.25, 'batteries_rated_discharge_power': 6600.0, 'batteries_rated_charge_power': 7500.0, 'batteries_charge_end_time_expected': '14:00', 'batteries_soc_setpoint_low': 15.0, 'batteries_soc_setpoint_neutral': 45.0, 'batteries_soc_setpoint_high': 75.0, 'epexspot_quantile_setpoint_low': 0.15, 'epexspot_quantile_setpoint_neutral': 0.33, 'epexspot_quantile_setpoint_high': 0.9}
0.9
0.0
4199.0
off
off
2024-07-30T14:19:37.170981+02:00
The automation on top of the sensor:
alias: Heating Pump - SG-Ready controller
description: "Heating Pump: SG-Ready controller."
minutes: /1
enabled: true
condition: []
- choose:
- conditions:
- condition: state
entity_id: sensor.sg_ready_mode
attribute: mode
state: EVU lock
sequence:
- if:
- condition: state
entity_id: switch.406_wp_sg_ready_evu
state: "off"
then:
- service: switch.turn_on
metadata: {}
data: {}
- if:
- condition: state
entity_id: switch.406_wp_sg_ready_pv_ma
state: "on"
then:
- service: switch.turn_off
metadata: {}
data: {}
- if:
- condition: state
entity_id: switch.heizung_domestic_hot_water_0_boost
state: "on"
then:
metadata: {}
data: {}
default:
- if:
- condition: state
state: "on"
then:
metadata: {}
data: {}
- if:
- condition: state
state: "on"
then:
metadata: {}
data: {}
- if:
- condition: state
state: "on"
then:
metadata: {}
data: {}
mode: single
Hellis81
(Hellis81)
July 30, 2024, 12:42pm
2
This is probably the issue.
Later you use:
which is the only place I can find >=
Make sure this value does not become unavailable or unknown in your macro
heinemannj
(Joerg Heinemann)
July 30, 2024, 12:44pm
3
Content of custom jinja template:
{%- macro globalVariables() %}
{# 1 x Huawei SUN2000-6KTL-M1 (High Current Version) #}
{# 1 x Huawei LUNA2000-10-S0 #}
{# 1 x Huawei LUNA2000-5-S0 #}
'batteries_rated_charge_energy': 17.250,
}|to_json -}}
{%- endmacro %}
Hellis81
(Hellis81)
July 30, 2024, 12:48pm
4
String… You can’t have a string there
heinemannj
(Joerg Heinemann)
July 30, 2024, 12:56pm
5
I don’t understand:
{{ var }}
"inverter_rated_power": 6000,
"inverter_maximum_active_power": 6600,
"batteries_rated_capacity": 15,
"batteries_rated_charge_energy": 17.25,
"batteries_rated_discharge_power": 6600,
"batteries_rated_charge_power": 7500,
"batteries_charge_end_time_expected": "14:00",
"batteries_soc_setpoint_low": 15,
"batteries_soc_setpoint_neutral": 45,
"batteries_soc_setpoint_high": 75,
"epexspot_quantile_setpoint_low": 0.15,
"epexspot_quantile_setpoint_neutral": 0.33,
"epexspot_quantile_setpoint_high": 0.9
var.batteries_charge_end_time_expected: {{ var.batteries_charge_end_time_expected }}
var.epexspot_quantile_setpoint_high: {{ var.epexspot_quantile_setpoint_high }}
var.batteries_charge_end_time_expected: 14:00
var.epexspot_quantile_setpoint_high: 0.9
The template in general is working as expected - but recurring errors - but the strange thing only on at some point of time
123
(Taras)
July 30, 2024, 1:15pm
6
I doubt this is the cause of the problem but let’s officially eliminate this unlikely possibility …
Do you have the following custom integration installed?
It’s used to create entities whose domain is var
and serve as global variables. For example, var.color
, var.intensity
, etc.
Now this is going to be quite a stretch but perhaps Home Assistant occasionally confuses the meaning of var.epexspot_quantile_setpoint_high
as being an entity belonging to that custom integration as opposed to a Jinja2 variable.
(Grasping at straws)
heinemannj
(Joerg Heinemann)
July 30, 2024, 1:19pm
7
I’ve NOT installed this custom integration.
(Taras)
July 30, 2024, 1:34pm
8
OK, good. The unlikely scenario is decisively eliminated.
FWIW, the order of the types reported in the error message is significant.
It means it encountered a numeric comparison between a string
and float
. As already mentioned, the only comparison involving >=
is this one:
Given the order of the reported types, string
and float
, means that epexspot_quantile_forecast
had a string
value.
Which seems impossible because this template ensures the value is float
heinemannj
(Joerg Heinemann)
July 30, 2024, 1:35pm
9
Something has happened this noon:
123
(Taras)
July 30, 2024, 1:44pm
11
Which, of course, doesn’t explain why the error message complains the lefthand value in the numeric comparison is a string.
Very strange.
I am looking this over, and wanted to remind everyone that everything returned from a
custom macro is a string. Everything.
That is likely a string.
(Taras)
July 30, 2024, 2:17pm
13
I’m hoping you can help me understand one particular aspect of this Trigger-based Template Sensor’s operation.
It’s regarding this availability
template:
availability: >-
If both switches are on
then the template’s result is on
, the sensor is available and its state
template will be evaluated.
If either switch is off
then the template’s result is off
, the sensor is unavailable and its state
template will not be evaluated.
So both switches must be on
in order for the state
template to be evaluated. However, the state
template is making decisions based on whether those same switches are either on
or off
How is it able to check if a switch is off
when the availability
template only allows evaluation when both switches are on
123
(Taras)
July 30, 2024, 2:20pm
14
True but the from_json
filter is being used to convert it to a dictionary.
heinemannj
(Joerg Heinemann)
July 30, 2024, 2:30pm
15
Potentially the availability template doesn’t make sense any more and I should remove this old stuff.
But as you can see above, there was no change on both of the switches during the issue …
123
(Taras)
July 30, 2024, 2:35pm
16
Sure but my question was about when things are operating normally.
The Template Sensor’s availability
template only allows the state
template to be evaluated when both switches are on
yet the state
template contains code that checks if they are on
or off
. It will never get an off
state because the availability
template (as its currently written) will not allow it.
I agree … or make the availability
template confirm that both switches have nominal values (on
or off
) and not unavailable
or unknown
availability: >-
{{ has_value('switch.406_wp_sg_ready_evu')
and has_value('switch.406_wp_sg_ready_pv_ma') }}
heinemannj
(Joerg Heinemann)
July 30, 2024, 2:39pm
17
{{ states('switch.406_wp_sg_ready_evu') and states('switch.406_wp_sg_ready_pv_ma') }}
off
heinemannj
(Joerg Heinemann)
July 30, 2024, 2:46pm
19
As you are writing above I was also on the way to understand the documentation properly …
Conclusion: My old availibility template needs to be removed!
Thanks for chaising me into the right direction!
I will adapt my configs and monitor and report.
123
(Taras)
July 30, 2024, 2:55pm
20
I suggest you use the template I posted above (the one that employs has_value
If you simply remove the availability
option and one of the two switches is unavailable
, it will cause your state
template to produce an incorrect misleading result.
Assume the first switch’s state is neither on
or off
but unavailable
or unknown
It will cause the state
template to report Normal
state: >-
{{ 'EVU lock' }}
{{ 'Turn On' }}
{% else %}
{{ 'Normal' }}
{% endif %}
So your choices are either to use an appropriate availability
template (like what I suggested above) or to enhance the state
template to handle non-nominal switch values.
