I had disabled a script for some time and when re-enabling and testing it, it raises an error. It used to work early April, some HA version upgrades ago.
The purpose of the script is to post a sensor value to an external web service using a POST API.
The error is:
2018-06-02 08:20:05 ERROR (MainThread) [homeassistant.components.shell_command] Error running command: `/usr/bin/curl {{ args|default('-sS') }} -X {{ method|default('get')|upper }} {%- for k in headers %} -H "{{ k }}: {{ headers[k] }}"{% endfor %} {{- (' -d \'' ~ payload|tojson ~ '\'') if payload }} {{ url }} > {{ stream|default('/dev/null') }}`, return code: 3
NoneType: None
This is the relevant config:
script:
## API documentation at https://www.mindergas.nl/member/api
post_mindergas:
alias: Post Gas Consumption
sequence:
- service: shell_command.curl
data_template:
url: https://www.mindergas.nl/api/gas_meter_readings
method: post
headers:
Content-Type: application/json
AUTH-TOKEN: !secret mindergas_token
payload:
date: "{{ (as_timestamp(now()) - (24*3600)) | timestamp_custom('%Y-%m-%d', True) }}"
reading: "{{ states.sensor.gas_consumption.state }}"
- service: logbook.log
message: is verstuurd naar mindergas.nl
entity_id: sensor.gas_consumption
domain: sensor
shell_command:
curl: >-
Can someone explain what the error means, why it’s raised and hopefully how to fix?
For the record, I’m using Hassio and curl is working in SSH:
➜ ~ which curl
/usr/bin/curl
