When I try to register my android device from chrome I see the following in the log:
2017-11-21 20:59:28 ERROR (MainThread) [homeassistant.util.json] Failed to serialize to JSON: /home/homeassistant/.homeassistant/html5_push_registrations.conf
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/util/json.py", line 38, in save_json
data = json.dumps(config, sort_keys=True, indent=4)
File "/usr/lib/python3.5/json/__init__.py", line 237, in dumps
**kw).encode(obj)
File "/usr/lib/python3.5/json/encoder.py", line 200, in encode
chunks = list(chunks)
File "/usr/lib/python3.5/json/encoder.py", line 429, in _iterencode
yield from _iterencode_dict(o, _current_indent_level)
File "/usr/lib/python3.5/json/encoder.py", line 403, in _iterencode_dict
yield from chunks
yield from chunks
yield from chunks
yield from chunks
File "/usr/lib/python3.5/json/encoder.py", line 436, in _iterencode
o = _default(o)
File "/usr/lib/python3.5/json/encoder.py", line 179, in default
raise TypeError(repr(o) + " is not JSON serializable")
TypeError: b'pRNH7pFGQ18HbYmRK0motQ==' is not JSON serializable
2017-11-21 20:59:28 ERROR (MainThread) [aiohttp.server] Error handling request
**kw).encode(obj)
yield from chunks
yield from chunks
yield from chunks
yield from chunks
o = _default(o)
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web_protocol.py", line 416, in start
resp = yield from self._request_handler(request)
File "/srv/homeassistant/lib/python3.5/site-packages/aiohttp/web.py", line 323, in _handle
resp = yield from handler(request)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/ban.py", line 58, in ban_middleware
return (yield from handler(request))
File "/usr/lib/python3.5/asyncio/coroutines.py", line 209, in coro
res = yield from res
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/http/__init__.py", line 430, in handle
result = yield from result
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/notify/html5.py", line 176, in post
if not save_json(self.json_path, self.registrations):
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/util/json.py", line 45, in save_json
raise HomeAssistantError(error)
homeassistant.exceptions.HomeAssistantError: b'pRNH7pFGQ18HbYmRK0motQ==' is not JSON serializable
In the html5 conf file I only see 1 entry from my desktop machine. The notifications to my phone work until I restart, then they stop working until I re-register.
