So I’m switching to a new computer, and for some reason after updating the SONOFF dongle - E version, I can’t connect it to Zigbee2mqtt.
This is the error in the logs:
Starting zigbee-herdsman (0.14.103)
Error: Reset error: Error: {"sequence":-1} after 10000ms
at /app/node_modules/zigbee-herdsman/src/adapter/ezsp/driver/uart.ts:298:23
at Queue.executeNext (/app/node_modules/zigbee-herdsman/src/utils/queue.ts:32:32)
The problem was that after updating the stick, the firmware on the stick was loaded with errors, and in fact the sonoff dongle E stick was without firmware. After I used another software to update the stick, the problem disappeared
