Hi every one
when i try to instal A123, use usb i get error
ERROR Serial port closed!
i use Generic x86-64 as server
how can check server port
Hi every one
WTH is A123? (or A128, you use both)
The A128 is an A-road in Essex, England.
(wikipedia)
The a128 combines all the navigation capabilities of the a125 with a built in Dual-channel, high-resolution CHIRP sonar.
(hudson marine)
A128 GATES HI POWER II V BELT
(various tool suppliers)
A128 , 5 ton RC Cylinder Attachment, Rubber Flex-Head.
(enerpac)
kc868-A128
Now yaml and wiring and logs please. No photos or screenshots please!
this error
Could not open /dev/ttyUSB0, the port doesn’t exist
how can Create it
Check that you actually have something mapped to ttyUSB0. Settings → System → Hardware → all hardware.
You should also provide more relevant information if you want help.
There’s your problem. Nothing is mapped to ttyUSB0.
Yes
how can Create it
You do not “create” usb-ports, this is created when you plug usb-devices in. You give no information about your setup, what you are trying to do and how you have wired this so it’s not possible to help you any further.
what can i do now
I would start by reading the replies to your posts.
Is there any alternative solution?
An alternative solution to you not providing details? Yes, that would be you actually providing details.
unplug the device.
run the command
dmesg -c
plug the device
run the command
dmesg
report what it says
i used mini pc
info
Home Assistant 2023.9.2
Supervisor 2023.09.2
Operating System 10.5
Frontend 20230911.0 - latest
i am trying install KC868-A128 ESP32 by using ESPHome
when i plug in device
after i run the installing
stop
INFO ESPHome 2023.8.3
INFO Reading configuration /config/esphome/a128.yaml...
WARNING GPIO15 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO4 is a Strapping PIN and should be avoided.
INFO Generating C++ source...
INFO Compiling app...
Processing a128 (board: esp32dev; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- WiFi @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Wire @ 2.0.0
RAM: [= ] 11.2% (used 36664 bytes from 327680 bytes)
Flash: [=== ] 34.0% (used 623289 bytes from 1835008 bytes)
========================= [SUCCESS] Took 3.67 seconds =========================
INFO Successfully compiled program.
esptool.py v4.6.2
Serial port /dev/ttyUSB0
Connecting......
Chip is ESP32-D0WD-V3 (revision v3.0)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: c0:49:ef:c8:ab:40
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 4MB
Flash will be erased from 0x00010000 to 0x000a8fff...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Compressed 624640 bytes to 375829...
Wrote 624640 bytes (375829 compressed) at 0x00010000 in 8.9 seconds (effective 558.8 kbit/s)...
Hash of data verified.
Compressed 17440 bytes to 12128...
Wrote 17440 bytes (12128 compressed) at 0x00001000 in 0.6 seconds (effective 217.5 kbit/s)...
Compressed 3072 bytes to 144...
Wrote 3072 bytes (144 compressed) at 0x00008000 in 0.1 seconds (effective 326.1 kbit/s)...
Compressed 8192 bytes to 47...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 630.9 kbit/s)...
Leaving...
Hard resetting via RTS pin...
INFO Successfully uploaded program.
INFO Starting log output from /dev/ttyUSB0 with baud rate 115200
[15:13:22]\x80 \x80 b\x9aA%]A\xe90xee
[15:13:22]clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
[15:13:22]mode:DIO, clock div:2
[15:13:22]load:0x3fff0030,len:1184
[15:13:22]load:0x40078000,len:13132
[15:13:22]load:0x40080400,len:3036
[15:13:22]entry 0x400805e4
[15:13:22][I][logger:262]: Log initialized
[15:13:23][I][app:029]: Running through setup()...
[15:13:23][I][i2c.arduino:183]: Performing I2C bus recovery
[15:13:23][C][pcf8574:010]: Setting up PCF8574...
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light1'...
[15:13:23][D][switch:016]: 'a128-light1' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light1': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light2'...
[15:13:23][D][switch:016]: 'a128-light2' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light2': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light3'...
[15:13:23][D][switch:016]: 'a128-light3' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light3': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light4'...
[15:13:23][D][switch:016]: 'a128-light4' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light4': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light5'...
[15:13:23][D][switch:016]: 'a128-light5' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light5': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light6'...
[15:13:23][D][switch:016]: 'a128-light6' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light6': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light7'...
[15:13:23][D][switch:016]: 'a128-light7' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light7': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light8'...
[15:13:23][D][switch:016]: 'a128-light8' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light8': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light9'...
[15:13:23][D][switch:016]: 'a128-light9' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light9': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light10'...
[15:13:23][D][switch:016]: 'a128-light10' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light10': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light11'...
[15:13:23][D][switch:016]: 'a128-light11' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light11': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light12'...
[15:13:23][D][switch:016]: 'a128-light12' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light12': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light13'...
[15:13:23][D][switch:016]: 'a128-light13' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light13': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light14'...
[15:13:23][D][switch:016]: 'a128-light14' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light14': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light15'...
[15:13:23][D][switch:016]: 'a128-light15' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light15': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light16'...
[15:13:23][D][switch:016]: 'a128-light16' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light16': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light17'...
[15:13:23][D][switch:016]: 'a128-light17' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light17': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light18'...
[15:13:23][D][switch:016]: 'a128-light18' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light18': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light19'...
[15:13:23][D][switch:016]: 'a128-light19' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light19': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light20'...
[15:13:23][D][switch:016]: 'a128-light20' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light20': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light21'...
[15:13:23][D][switch:016]: 'a128-light21' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light21': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light22'...
[15:13:23][D][switch:016]: 'a128-light22' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light22': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light23'...
[15:13:23][D][switch:016]: 'a128-light23' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light23': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light24'...
[15:13:23][D][switch:016]: 'a128-light24' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light24': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light25'...
[15:13:23][D][switch:016]: 'a128-light25' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light25': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light26'...
[15:13:23][D][switch:016]: 'a128-light26' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light26': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light27'...
[15:13:23][D][switch:016]: 'a128-light27' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light27': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light28'...
[15:13:23][D][switch:016]: 'a128-light28' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light28': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light29'...
[15:13:23][D][switch:016]: 'a128-light29' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light29': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light30'...
[15:13:23][D][switch:016]: 'a128-light30' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light30': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light31'...
[15:13:23][D][switch:016]: 'a128-light31' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light31': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light32'...
[15:13:23][D][switch:016]: 'a128-light32' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light32': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light33'...
[15:13:23][D][switch:016]: 'a128-light33' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light33': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light34'...
[15:13:23][D][switch:016]: 'a128-light34' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light34': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light35'...
[15:13:23][D][switch:016]: 'a128-light35' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light35': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light36'...
[15:13:23][D][switch:016]: 'a128-light36' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light36': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light37'...
[15:13:23][D][switch:016]: 'a128-light37' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light37': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light38'...
[15:13:23][D][switch:016]: 'a128-light38' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light38': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light39'...
[15:13:23][D][switch:016]: 'a128-light39' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light39': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light40'...
[15:13:23][D][switch:016]: 'a128-light40' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light40': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light41'...
[15:13:23][D][switch:016]: 'a128-light41' Turning OFF.
[15:13:23][D][switch:055]: 'a128-light41': Sending state OFF
[15:13:23][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light42'...
[15:13:24][D][switch:016]: 'a128-light42' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light42': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light43'...
[15:13:24][D][switch:016]: 'a128-light43' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light43': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light44'...
[15:13:24][D][switch:016]: 'a128-light44' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light44': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light45'...
[15:13:24][D][switch:016]: 'a128-light45' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light45': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light46'...
[15:13:24][D][switch:016]: 'a128-light46' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light46': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light47'...
[15:13:24][D][switch:016]: 'a128-light47' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light47': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light48'...
[15:13:24][D][switch:016]: 'a128-light48' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light48': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light49'...
[15:13:24][D][switch:016]: 'a128-light49' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light49': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light50'...
[15:13:24][D][switch:016]: 'a128-light50' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light50': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light51'...
[15:13:24][D][switch:016]: 'a128-light51' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light51': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light52'...
[15:13:24][D][switch:016]: 'a128-light52' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light52': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light53'...
[15:13:24][D][switch:016]: 'a128-light53' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light53': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light54'...
[15:13:24][D][switch:016]: 'a128-light54' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light54': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light55'...
[15:13:24][D][switch:016]: 'a128-light55' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light55': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light56'...
[15:13:24][D][switch:016]: 'a128-light56' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light56': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light57'...
[15:13:24][D][switch:016]: 'a128-light57' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light57': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light58'...
[15:13:24][D][switch:016]: 'a128-light58' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light58': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light59'...
[15:13:24][D][switch:016]: 'a128-light59' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light59': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light60'...
[15:13:24][D][switch:016]: 'a128-light60' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light60': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light61'...
[15:13:24][D][switch:016]: 'a128-light61' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light61': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light62'...
[15:13:24][D][switch:016]: 'a128-light62' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light62': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light63'...
[15:13:24][D][switch:016]: 'a128-light63' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light63': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light64'...
[15:13:24][D][switch:016]: 'a128-light64' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light64': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light65'...
[15:13:24][D][switch:016]: 'a128-light65' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light65': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light66'...
[15:13:24][D][switch:016]: 'a128-light66' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light66': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light67'...
[15:13:24][D][switch:016]: 'a128-light67' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light67': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light68'...
[15:13:24][D][switch:016]: 'a128-light68' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light68': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light69'...
[15:13:24][D][switch:016]: 'a128-light69' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light69': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light70'...
[15:13:24][D][switch:016]: 'a128-light70' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light70': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light71'...
[15:13:24][D][switch:016]: 'a128-light71' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light71': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light72'...
[15:13:24][D][switch:016]: 'a128-light72' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light72': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light73'...
[15:13:24][D][switch:016]: 'a128-light73' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light73': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light74'...
[15:13:24][D][switch:016]: 'a128-light74' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light74': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light75'...
[15:13:24][D][switch:016]: 'a128-light75' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light75': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light76'...
[15:13:24][D][switch:016]: 'a128-light76' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light76': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light77'...
[15:13:24][D][switch:016]: 'a128-light77' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light77': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light78'...
[15:13:24][D][switch:016]: 'a128-light78' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light78': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light79'...
[15:13:24][D][switch:016]: 'a128-light79' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light79': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light80'...
[15:13:24][D][switch:016]: 'a128-light80' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light80': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light81'...
[15:13:24][D][switch:016]: 'a128-light81' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light81': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light82'...
[15:13:24][D][switch:016]: 'a128-light82' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light82': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light83'...
[15:13:24][D][switch:016]: 'a128-light83' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light83': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light84'...
[15:13:24][D][switch:016]: 'a128-light84' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light84': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light85'...
[15:13:24][D][switch:016]: 'a128-light85' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light85': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light86'...
[15:13:24][D][switch:016]: 'a128-light86' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light86': Sending state OFF
[15:13:24][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light87'...
[15:13:24][D][switch:016]: 'a128-light87' Turning OFF.
[15:13:24][D][switch:055]: 'a128-light87': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light88'...
[15:13:25][D][switch:016]: 'a128-light88' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light88': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light89'...
[15:13:25][D][switch:016]: 'a128-light89' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light89': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light90'...
[15:13:25][D][switch:016]: 'a128-light90' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light90': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light91'...
[15:13:25][D][switch:016]: 'a128-light91' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light91': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light92'...
[15:13:25][D][switch:016]: 'a128-light92' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light92': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light93'...
[15:13:25][D][switch:016]: 'a128-light93' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light93': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light94'...
[15:13:25][D][switch:016]: 'a128-light94' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light94': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light95'...
[15:13:25][D][switch:016]: 'a128-light95' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light95': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light96'...
[15:13:25][D][switch:016]: 'a128-light96' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light96': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light97'...
[15:13:25][D][switch:016]: 'a128-light97' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light97': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light98'...
[15:13:25][D][switch:016]: 'a128-light98' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light98': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light99'...
[15:13:25][D][switch:016]: 'a128-light99' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light99': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light100'...
[15:13:25][D][switch:016]: 'a128-light100' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light100': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light101'...
[15:13:25][D][switch:016]: 'a128-light101' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light101': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light102'...
[15:13:25][D][switch:016]: 'a128-light102' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light102': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light103'...
[15:13:25][D][switch:016]: 'a128-light103' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light103': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light104'...
[15:13:25][D][switch:016]: 'a128-light104' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light104': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light105'...
[15:13:25][D][switch:016]: 'a128-light105' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light105': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light106'...
[15:13:25][D][switch:016]: 'a128-light106' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light106': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light107'...
[15:13:25][D][switch:016]: 'a128-light107' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light107': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light108'...
[15:13:25][D][switch:016]: 'a128-light108' Turning OFF.
[15:13:25][D][switch:055]: 'a128-light108': Sending state OFF
[15:13:25][C][switch.gpio:011]: Setting up GPIO Switch 'a128-light109'...
[15:13:25][D][switch:016]: 'a128-light109' Turning OFF.'....
[15:13:25][D][binary_sensor:034]: 'a128-input1': Sending initial state OFF
[15:13:25][D][binary_sensor:034]: 'a128-input2': Sending initial state OFF
[15:13:25][D][binary_sensor:034]: 'a128-input3': Sending initial state OFF
[15:13:25][D][binary_sensor:034]: 'a128-input4': Sending initial state OFF
[15:13:25][D][binary_sensor:034]: 'a128-input5': Sending initial state OFF
[15:13:25][D][binary_sensor:034]: 'a128-input6': Sending initial state OFF
[15:13:25][D][binary_sensor:034]: 'a128-input7': Sending initial state OFF
[15:13:25][D][binary_sensor:034]: 'a128-input8': Sending initial state OFF
[15:13:25][D][binary_sensor:034]: 'a128-input9': Sending initial state OFF
[15:13:25][D][binary_sensor:034]: 'a128-input10': Sending initial state OF
[15:13:26][D][binary_sensor:034]: 'a128-input49': Sending initial state OFF
[15:13:26][D][binary_sensor:034]: 'a128-input50': Sending initial state OFF
[15:13:26][D][binary_sensor:034]: 'a128-input51': Sending initial state OFF
[15:13:26][D][binary_sensor:034]: 'a128-input52': Sending initial state OFF
[15:13:26][C][ethernet:028]: Setting up Ethernet...
thank you all
i fixed it
Please do tell us how so that other people can benefit.
