Error setting up August Lock
Is anybody successfully using August Lock with HA?
I just installed lock at home with HomeKit and tried to configure it in HA, but I get an error.
I received a code from august upon first boot of HA, but august lock never showed up in the gui.
When I examined the log, I saw errors posted below.
I raised a bug request here:
https://github.com/home-assistant/home-assistant/issues/13815
Basically here is the error log:
2018-04-11 07:16:53 INFO (MainThread) [homeassistant.components.lock] Setting up lock.august
2018-04-11 07:16:54 ERROR (MainThread) [homeassistant.components.lock] august: Error on device update!
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 188, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 327, in async_device_update
    yield from self.hass.async_add_job(self.update)
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/usr/lib/python3.6/site-packages/homeassistant/components/lock/august.py", line 50, in update
    self._lock_status = self._data.get_lock_status(self._lock.device_id)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/august.py", line 229, in get_lock_status
    self._update_locks()
  File "/usr/lib/python3.6/site-packages/homeassistant/util/__init__.py", line 319, in wrapper
    result = method(*args, **kwargs)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/august.py", line 244, in _update_locks
    self._access_token, lock.device_id)
  File "/usr/lib/python3.6/site-packages/august/api.py", line 204, in get_lock_status
    access_token=access_token).json()
  File "/usr/lib/python3.6/site-packages/august/api.py", line 243, in _call_api
    response.raise_for_status()
  File "/usr/lib/python3.6/site-packages/requests/models.py", line 935, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 409 Client Error: Conflict for url: https://api-production.august.com/locks/D6DA2278....mykey/status
2018-04-11 07:16:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event system_log_event[L]: timestamp=1523402214.8573093, level=ERROR, message=august: Error on device update!, exception=Traceback (most recen
, source=components/august.py>
2018-04-11 07:16:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=group, service=set, service_data=object_id=all_locks, name=all locks, entities=[], visible=False, service_call_i
2018-04-11 07:16:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_locks, old_state=None, new_state=<state group.all_locks=unknown; entity_id=(), order=4, auto=True,
2018-04-11 07:16:54 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1968328496-4>
I am running Hassio on a Raspberry Pi. I upgraded the software to HassOS 1.9 version 126, and I instantly recieved an authentication code for the August component. Looks like someone fixed the issue!
Hi, after receiving the code. Where should the code be place on hassio?
Swooshnoypi, If you go to your home screen, you’ll see a new tile for your lock. In the bottom corner of the tile there is a link that says “configure”. Click on that link, and you can enter you authentication code you recieved by text. After this step you should be up and running.
Hi jgrimble, yeah i just notice that notification did not pop-up as I was using lovelace. After I use the normal view, then I could see the “configure” and managed to key in the code. Many thanks for the prompt reply and sharing info. Cheers…
