Hello Folks,
I am encountering an issue while trying to set up the Govee local integration in Home Assistant. I would appreciate any help or guidance in resolving this problem.
Error Details:
I am receiving the following error when setting up the Govee local integration:
Error setting up entry Govee light local for govee_light_local
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 551, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/govee_light_local/__init__.py", line 24, in async_setup_entry
await coordinator.start()
File "/usr/src/homeassistant/homeassistant/components/govee_light_local/coordinator.py", line 48, in start
await self._controller.start()
File "/usr/local/lib/python3.12/site-packages/govee_local_api/controller.py", line 98, in start
self._transport, self._protocol = await self._loop.create_datagram_endpoint(
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1421, in create_datagram_endpoint
raise exceptions[0]
File "/usr/local/lib/python3.12/asyncio/base_events.py", line 1405, in create_datagram_endpoint
sock.bind(local_address)
OSError: [Errno 98] Address in use
System Information:
- Home Assistant version: 2024.4.0
- Installation type: Home Assistant OS
- Govee local integration version: Latest from HACS
Additional Context:
- I am also running the Govee2MQTT integration alongside the Govee local integration.
- I have tried configuring the Govee local integration through the Home Assistant UI (Integrations page) as YAML configuration is not supported.
- The error occurs consistently whenever I try to set up the Govee local integration.
Troubleshooting Steps Tried:
- Restarting Home Assistant
- Checking for conflicting applications or services using the same port
- Reviewing Home Assistant logs for additional error messages
I would greatly appreciate any suggestions, workarounds, or insights into resolving this “Address in use” error and successfully setting up the Govee local integration.
Thank you in advance for your help!
Owen
