I’m trying to select an input_boolean entity when configuring the final " Advanced Configuration" section of a HomeKit bridge.
The input_boolean is presented as selectable, but generates the error “Failed to set up”. Selecting any other item in the list works okay.
The logs presents the following;
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 444, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/homekit/__init__.py", line 357, in async_setup_entry
await homekit.async_start()
File "/usr/src/homeassistant/homeassistant/components/homekit/__init__.py", line 847, in async_start
if not await self._async_create_accessories():
File "/usr/src/homeassistant/homeassistant/components/homekit/__init__.py", line 1032, in _async_create_accessories
acc = await self._async_create_bridge_accessory(entity_states)
File "/usr/src/homeassistant/homeassistant/components/homekit/__init__.py", line 978, in _async_create_bridge_accessory
await self._async_add_trigger_accessories()
File "/usr/src/homeassistant/homeassistant/components/homekit/__init__.py", line 998, in _async_add_trigger_accessories
await device_automation.async_get_device_automations(
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 269, in async_get_device_automations
for domain_results in await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/components/device_automation/__init__.py", line 228, in _async_get_device_automations_from_domain
return await asyncio.gather( # type: ignore[no-any-return]
File "/usr/src/homeassistant/homeassistant/components/mqtt/device_trigger.py", line 354, in async_get_triggers
mqtt_data = get_mqtt_data(hass)
File "/usr/src/homeassistant/homeassistant/components/mqtt/util.py", line 179, in get_mqtt_data
mqtt_data = hass.data[DATA_MQTT]
KeyError: 'mqtt'
Should I be able to add an input_boolean?
