Error setting up ios with datetime is not JSON serializable error
I am trying to setup the ios component but when I restart home assistant after adding the ios: entry to my configuration.yaml I get the following error in the log:
[homeassistant.components.notify.ios] The notify.ios platform was loaded but no devices exist! Please check the documentation at https://home-assistant.io/ecosystem/ios/notifications/ for more information
Then when I load the iPhone app I get two of the following in the log:
2018-01-01 12:11:51 ERROR (MainThread) [homeassistant.util.json] Failed to serialize to JSON: /home/homeassistant/.homeassistant/.ios.conf
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/util/json.py", line 38, in save_json
    data = json.dumps(config, sort_keys=True, indent=4)
  File "/usr/lib/python3.4/json/__init__.py", line 237, in dumps
    **kw).encode(obj)
  File "/usr/lib/python3.4/json/encoder.py", line 194, in encode
    chunks = list(chunks)
  File "/usr/lib/python3.4/json/encoder.py", line 422, in _iterencode
    yield from _iterencode_dict(o, _current_indent_level)
  File "/usr/lib/python3.4/json/encoder.py", line 396, in _iterencode_dict
    yield from chunks
    yield from chunks
    yield from chunks
  File "/usr/lib/python3.4/json/encoder.py", line 429, in _iterencode
    o = _default(o)
  File "/usr/lib/python3.4/json/encoder.py", line 173, in default
    raise TypeError(repr(o) + " is not JSON serializable")
TypeError: datetime.datetime(2018, 1, 1, 12, 11, 51, 526289) is not JSON serializable
When I check the folder, I do not have an .ios.conf file.
Does anyone know how I can fix this and get up and running with ios?
