I’ve successfully set up the Onvif integration with username/password to my camera however I’m unable to see any device or entities created so I can access the stream.
Log shows the following error
Logger: homeassistant.config_entries
Source: components/onvif/event.py:77
First occurred: July 2, 2020, 10:46:04 PM (1 occurrences)
Last logged: July 2, 2020, 10:46:04 PM
Error setting up entry Gate - 00:5A:20:31:BC:01 for onvif
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 936, in _wrap_create_connection
return await self._loop.create_connection(*args, **kwargs) # type: ignore # noqa
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 962, in create_connection
raise exceptions[0]
File "/usr/local/lib/python3.7/asyncio/base_events.py", line 949, in create_connection
await self.sock_connect(sock, address)
File "/usr/local/lib/python3.7/asyncio/selector_events.py", line 473, in sock_connect
return await fut
File "/usr/local/lib/python3.7/asyncio/selector_events.py", line 503, in _sock_connect_cb
raise OSError(err, f'Connect call failed {address}')
ConnectionRefusedError: [Errno 111] Connect call failed ('10.0.1.211', 7655)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 220, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/onvif/__init__.py", line 83, in async_setup_entry
if device.capabilities.events and await device.events.async_start():
File "/usr/src/homeassistant/homeassistant/components/onvif/event.py", line 77, in async_start
await pullpoint.SetSynchronizationPoint()
File "/usr/local/lib/python3.7/site-packages/zeep/asyncio/bindings.py", line 13, in send
options["address"], envelope, http_headers
File "/usr/local/lib/python3.7/site-packages/zeep/asyncio/transport.py", line 107, in post_xml
response = await self.post(address, message, headers)
File "/usr/local/lib/python3.7/site-packages/zeep/asyncio/transport.py", line 95, in post
proxy=self.proxy,
File "/usr/local/lib/python3.7/site-packages/aiohttp/client.py", line 483, in _request
timeout=real_timeout
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 523, in connect
proto = await self._create_connection(req, traces, timeout)
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 859, in _create_connection
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 1004, in _create_direct_connection
raise last_exc
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 986, in _create_direct_connection
req=req, client_error=client_error)
File "/usr/local/lib/python3.7/site-packages/aiohttp/connector.py", line 943, in _wrap_create_connection
raise client_error(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host 10.0.1.211:7655 ssl:None [Connect call failed ('10.0.1.211', 7655)]
Connection lost. Reconnecting…
