Is anyone getting error - [homeassistant.components.notify] Error setting up platform telegram.
My telegram Id is working fine as i get images of ftp on my bot from script on rpi but cannot setup in notify.My notify.yaml config is like -
Can you post the full error from home_assistant.log? There should be some additional lines before the “error setting up platform” message. For instance, you may be missing a dependency.
17-03-06 02:33:44 ERROR (MainThread) [homeassistant.components.notify] Error setting up platform telegram
File “/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/notify/init.py”, line 101, in async_setup_platform
None, platform.get_service, hass, p_config, discovery_info)
File “/usr/lib/python3.4/asyncio/futures.py”, line 388, in iter
yield self # This tells Task to wait for completion.
File “/usr/lib/python3.4/asyncio/tasks.py”, line 286, in _wakeup
I cleared the log file and restarted HA now i am getting error -
17-03-06 09:38:21 ERROR (MainThread) [homeassistant.components.notify] Error setting up platform telegram
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/notify/__init__.py", line 101, in async_setup_platform
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/notify/telegram.py", line 48, in get_service
bot = telegram.Bot(token=api_key)
File "/home/homeassistant/.homeassistant/deps/telegram/bot.py", line 53, in __init__
self.token = self._validate_token(token)
File "/home/homeassistant/.homeassistant/deps/telegram/bot.py", line 79, in _validate_token
raise InvalidToken()
telegram.error.InvalidToken: Invalid token
