Hello Community,
I was impressed with the fast and easy setup of hass.io, unfortunately I ran into an Error:
Raspberry Pi RF Switch Devices are not showing up, neither in the Overview nor in the dev-state.
My configuration looks like the platform example. I get the following message in the log file: /config/home-assistant.log
2019-03-14 16:21:05 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2019-03-14 16:21:05 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform rpi_rf
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 128, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/switch/rpi_rf.py", line 50, in setup_platform
import rpi_rf
File "/usr/local/lib/python3.7/site-packages/rpi_rf/__init__.py", line 2, in <module>
from .rpi_rf import RFDevice
File "/usr/local/lib/python3.7/site-packages/rpi_rf/rpi_rf.py", line 9, in <module>
from RPi import GPIO
File "/usr/local/lib/python3.7/site-packages/RPi/GPIO/__init__.py", line 23, in <module>
from RPi._GPIO import *
RuntimeError: This module can only be run on a Raspberry Pi!
2019-03-14 16:21:06 ERROR (SyncWorker_11) [homeassistant.components.ios.notify] The notify.ios platform was loaded but no devices exist! Please check the documentation at https://home-assistant.io/ecosystem/ios/notifications/ for more information
The first line can be avoided by manually creating an empty “/config/known_devices.yaml” file. But I have no idea how to solve the other lines.
I’m new to the Community as well as to Home Assistant, hopefully someone is able to help. Any idea on how to fix this is welcome. Thanks in advance!
