Trying to set up the TrackR integration but running in to following error:
Logger: homeassistant.components.device_tracker
Source: util/__init__.py:47
Integration: Device tracker (documentation, issues)
First occurred: 2:54:42 PM (1 occurrences)
Last logged: 2:54:42 PM
Error setting up platform legacy
File "/usr/src/homeassistant/homeassistant/components/device_tracker/legacy.py", line 239, in async_setup_legacy
setup = await hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/trackr/device_tracker.py", line 22, in setup_scanner
TrackRDeviceScanner(hass, config, see)
File "/usr/src/homeassistant/homeassistant/components/trackr/device_tracker.py", line 38, in __init__
self._update_info()
File "/usr/src/homeassistant/homeassistant/components/trackr/device_tracker.py", line 55, in _update_info
dev_id = slugify(trackr.name())
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 47, in slugify
return unicode_slug.slugify(text, separator=separator)
File "/usr/local/lib/python3.8/site-packages/slugify/slugify.py", line 104, in slugify
text = _unicode(text, 'utf-8', 'ignore')
TypeError: decoding to str: need a bytes-like object, NoneType found
configuration.yaml
device_tracker:
- platform: trackr
username: !secret trackr_username
password: !secret trackr_password
Running hassos on proxmox
Supervisor: 2020.12.7
Homeassistant 5.9
Anyone who have any idea how to solve this?
