Hey Everyone!
I’ve been trying to split my modbus sensors into multiple files, a yaml for each device for my Solar configuration.
I have read and researched this topic, but I have not had much luck. So, I am reaching out to have someone help me out.
As a newbie my configuration has grown and I would like to make it more manageable now, rather than later.
Listed below is my MODBUS config in the configuration yaml below, and used sensor: !include_dir_merge_list sensors/ to load the sensors from each separate yaml file located in /sensors folder. There are three connections that need to be made, two look similar but I connect to different ports for different registers.
With about 3,000 lines of yaml -soon to double or so- when I add templates etc., So I’m trying to figure this out now.
I have enabled a logger, but Im not receiving any real errors, the connections are made.
This is my test configuaton, I have a working configuration where everything is posted to one yaml file:
working configuration.yaml file:
working configuation.yaml
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
#sensor: !include test.sensors.yaml
influxdb:
host: a0d7b954-influxdb
port: 8086
database: homeassistant
username: homeassistant
password: homeassistant
max_retries: 3
default_measurement: state
##########SEMB_BMS 0 Modbus SlaveAddress (Port 502): 230#########
modbus:
# - name: Victron_GX
# type: tcp
# host: 192.168.1.164
# port: 502
# delay: 2
# timeout: 15
# sensors:
# - name: "Victron Battery State Of Charge"
# unit_of_measurement: "%"
# slave: 224
# address: 266
# data_type: uint16
# scale: 0.1
# precision: 1
# device_class: power
# - name: "Victron Battery current"
# unique_id: 8529994b-63a2-4f4d-b008-d3fc76c36ba7
# unit_of_measurement: "A"
# slave: 224
# address: 841
# data_type: int16
# scale: 0.1
# precision: 0
# device_class: current
# - name: "Victron Battery Power System"
# unique_id: b5c7f95a-96ee-4562-99df-321d1344a572
# unit_of_measurement: "W"
# slave: 224
# address: 842
# data_type: int16
# scale: 1.0
# precision: 0
# - name: "Victron Charge Power System"
# unique_id: 4d43f46e-dd6b-49b9-a2f5-a36eb14fad3b
# slave: 224
# address: 860
# data_type: int16
# scale: 10.0
# precision: 0
# - name: "Victron Battery State of Charge System"
# unique_id: bb4386c8-151e-4938-8ce9-7cb0ec619b1c
# slave: 224
# address: 843
# data_type: uint16
# scale: 1
# precision: 0
# - name: "Victron Battery Voltage"
# unique_id: 3f9a4472-785d-4f69-915b-7691d23c2edc
# unit_of_measurement: "V"
# slave: 224
# address: 259
# data_type: uint16
# scale: 0.01
# precision: 1
# device_class: voltage
# - name: "Victron Battery Amperage"
# unique_id: 615a27b6-cef1-44e2-a5c2-effb4f8fec42
# slave: 224
# address: 261
# data_type: uint16
# scale: 0.1
# precision: 1
# - name: "Victron Battery Consumed Amphours"
# unique_id: 9e5c5c31-7e70-448b-8e0b-213d9673ba45
# slave: 224
# address: 265
# data_type: uint16
# scale: 0.1
# precision: 1
# - name: "Victron Battery Capacity"
# unique_id: c4f4eedd-3696-45d8-a6e0-2815dc1e0e5f
# slave: 224
# address: 309
# data_type: uint16
# scale: 0.1
# precision: 1
- name: EG4_Internal_BMS
type: tcp
host: 192.168.1.179
port: 502
delay: 2
timeout: 15
sensors:
- name: "EG4 Internal BMS - Battery SOC"
unique_id: d190cd3a-90c9-4a2c-8edc-3d71bce8604f
data_type: uint16
unit_of_measurement: V
scale: 1
precision: 2
slave: 230
address: 40081
scan_interval: 15
- name: "EG4 Internal BMS - Battery Current"
unique_id: 33aa654a-b639-4adc-97fa-ceea9444453a
data_type: int16
unit_of_measurement: A
scale: 0.01
precision: 2
slave: 230
address: 40114
scan_interval: 1
- name: "EG4 Internal BMS - Battery Voltage"
unique_id: 70a324c4-2f74-4c41-80e2-e4ada3896a89
data_type: uint16
scale: 0.01
precision: 2
slave: 230
address: 40104
scan_interval: 1
- name: Conext_Gateway
type: tcp
host: 192.168.1.179
port: 503
delay: 2
timeout: 15
sensors:
- name: "0 - XW 4868 Inverter Enabled"
unique_id: e71bdc4d-fbb1-483a-a864-521747ebc3dc
data_type: uint16
input_type: input
slave: 10
address: 71
scan_interval: 1
- name: "0 - XW 4868 Active Faults Flag"
unique_id: cb59ac1b-89e5-4fbe-9657-296ff6a7391f
data_type: uint16
input_type: input
slave: 10
address: 75
scan_interval: 1
- name: "0 - XW 4868 Active Warnings Flag"
unique_id: f1e2c225-c082-44fe-9b56-075d3ff25106
data_type: uint16
input_type: input
slave: 10
address: 76
scan_interval: 1
- name: "0 - XW 4868 Battery Current"
unique_id: f9bd9163-a48f-4f15-8cc9-e74887d07076
data_type: int32
input_type: input
slave: 10
address: 82
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
- name: "0 - XW 4868 Battery Power"
unique_id: bdeb06ec-3c2d-432b-8d6d-f19d45756602
data_type: int32
input_type: input
slave: 10
address: 84
scale: 1
offset: 0
precision: 0
device_class: energy
unit_of_measurement: W
scan_interval: 1
- name: "0 - XW 4868 Battery Temperature"
unique_id: 6707fd83-73ef-4814-83cd-38327cee0a88
data_type: uint16
input_type: input
slave: 10
address: 86
unit_of_measurement: degC
scale: 0.01
offset: -273
precision: 2
scan_interval: 1
- name: "0 - XW 4868 Inverter Status"
unique_id: 267469d6-8721-4504-8974-87088f8eb4ce
data_type: uint16
input_type: input
slave: 10
address: 122
scan_interval: 1
- name: "0 - XW 4868 Load AC Voltage"
unique_id: bba089ce-887c-48bc-8a41-4f7da31d17ce
data_type: uint32
input_type: input
slave: 10
address: 140
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
- name: "0 - XW 4868 Load AC Current"
unique_id: 7969546e-9059-43a1-8f78-9d665938b0fd
data_type: int32
input_type: input
slave: 10
address: 150
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
- name: "0 - XW 4868 Load AC Frequency"
unique_id: 6edecfad-d8f9-4e1c-91b2-c817e1ad042a
data_type: uint16
input_type: input
slave: 10
address: 152
unit_of_measurement: Hz
scale: 0.01
offset: 0
precision: 2
scan_interval: 1
- name: "0 - XW 4868 Load AC Power"
unique_id: 321d71e7-73bc-402a-82b9-c2f6015fd5d7
data_type: int32
input_type: input
slave: 10
address: 154
scale: 1
offset: 0
precision: 0
scan_interval: 1
############# NEW ###########################
# - name: "0 - XW 4868 AC Input Power"
# data_type: uint32
# unit_of_measurement: W
# scale: 1
# slave: 10
# address: 100
# device_class: energy
- name: "0 - XW 4868 Charge DC Power"
unique_id: 0986622f-7474-46b6-a615-71678cfe207d
data_type: uint32
scale: 1
slave: 10
address: 94
- name: "0 - XW 4868 Load Output Energy Today"
unique_id: 6853a55b-dbe0-48eb-b586-db5b1777dfba
data_type: uint32
unit_of_measurement: kWh
scale: 0.001
precision: 1
slave: 10
address: 308
state_class: total_increasing
- name: "0 - XW 4868 Energy From Battery This Hour"
unique_id: aa67ad1a-9953-4407-9e2d-0a4510cb67d5
data_type: uint32
scale: 0.001
precision: 1
slave: 10
address: 208
- name: "0 - XW 4868 Energy to Battery This Hour"
unique_id: d006ec0a-f23c-4ff9-b575-8458be40de92
data_type: uint32
scale: 0.001
precision: 1
slave: 10
address: 232
# - name: "0 - XW 4868 Generator Status"
# data_type: uint16
# scale: 1
# slave: 10 #51
# address: 77
- name: "0 - XW 4868 Energy from Battery This Hour"
unique_id: e1727361-a43e-4a57-a80d-08ed1f09f0ba
data_type: uint32
scale: 0.001
precision: 1
slave: 10
address: 208
unique_id: e9317bae-b986-4a87-b8af-a94d80e355ae
data_type: uint32
scale: 0.001
precision: 1
slave: 10
address: 232
########## (0) conext_gateway device over Modbus: MPPT600/100 Modbus Slave Address (Port 503): 170 #########
- name: "0 - MPPT100/600 100/600 Device State"
unique_id: d1b7829a-d3bf-4d7f-93b3-6dbf07c3da05
data_type: uint16
input_type: input
slave: 170
address: 64
scan_interval: 1
- name: "0 - MPPT100/600 Charger Enabled Status"
unique_id: 3e1f0eef-2c61-40aa-b036-eccfc46a2ad6
data_type: uint16
input_type: input
slave: 170
address: 65
scan_interval: 1
- name: "0 - MPPT100/600 Charge Mode Status"
unique_id: 8fd8118b-1694-433e-b7bb-ff195ac6dae4
data_type: uint16
input_type: input
slave: 170
address: 67
scan_interval: 1
- name: "0 - MPPT100/600 100/600 Active Faults"
unique_id: a6d4b7c4-7d60-4fff-974a-df8c0b521c8e
data_type: uint16
input_type: input
slave: 170
address: 68
scan_interval: 1
- name: "0 - MPPT100/600 Active Warnings"
unique_id: 2c0a23f0-1d90-44fc-9ef1-49079e2ef7dd
data_type: uint16
input_type: input
slave: 170
address: 69
scan_interval: 1
- name: "0 - MPPT100/600 PV Input Voltage"
unique_id: b4cb3cb2-2fc7-455d-8321-fdf55b372990
data_type: uint32
input_type: input
slave: 170
address: 76
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
- name: "0 - MPPT100/600 PV Input Current"
unique_id: 8bbc3a6b-b226-449b-9b87-c550ccda7762
data_type: uint32
input_type: input
slave: 170
address: 78
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
- name: "0 - MPPT100/600 PV Input Power"
unique_id: 70333220-5b59-4914-8b82-e1a12eefa72b
data_type: uint32
input_type: input
slave: 170
address: 80
scale: 1.0
offset: 0
precision: 0
scan_interval: 1
- name: "0 - MPPT100/600 Battery Temperature"
unique_id: 1a2a2523-775d-41d7-a873-777e08007d4e
data_type: uint16
input_type: input
slave: 170
address: 86
scale: 0.01
offset: -273
precision: 2
scan_interval: 1
- name: "0 - MPPT100/600 PV Output Voltage"
unique_id: 69b0fdec-7fd0-4e40-9c0e-0b7a835fbede
data_type: int32
input_type: input
slave: 170
address: 88
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
- name: "0 - MPPT100/600 PV Output Current"
unique_id: f3622ff7-9fd2-4eb0-94e8-aa14586059ae
data_type: int32
input_type: input
slave: 170
address: 90
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
- name: "0 - MPPT100/600 PV Output Power"
unique_id: 02e364b3-89bf-4e55-b288-49593449c28e
data_type: uint32
input_type: input
slave: 170
address: 92
scale: 1
offset: 0
precision: 0
scan_interval: 1
- name: "0 - MPPT100/600 Energy From PV This Hour"
unique_id: f3c1bc8f-d11a-4fe8-9bf0-a532879c86cd
data_type: uint32
input_type: input
slave: 170
address: 112
scale: 0.001
offset: 0
precision: 3
- name: "0 - MPPT100/600 PV Input Active This Hour"
unique_id: fddc9482-29fd-4905-a00e-2eac5913f85a
data_type: uint32
input_type: input
slave: 170
address: 114
unit_of_measurement: s
scale: 0.001
offset: 0
precision: 3
#############UNUSED###########################
# - name: "MPPT Energy From PV Today"
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 106
# unit_of_measurement: kWh
# scale: 0.001
# offset: 0
# precision: 3
# - name: "MPPT PV Input Active Today"
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 106
# scale: 0.001
# offset: 0
# precision: 3
# - name: "MPPT Energy From PV This Week"
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 110
# scale: 0.001
# offset: 0
# precision: 3
# - name: "MPPT PV Input Active This Week"
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 112
# scale: 0.001
# offset: 0
# precision: 3
# - name: "MPPT Energy From PV This Month"
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 114
# scale: 0.001
# offset: 0
# precision: 3
# - name: "MPPT PV Input Active This Month"
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 116
# scale: 0.001
# offset: 0
# precision: 3
# - name: "MPPT Energy From PV This Year"
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 118
# scale: 0.001
# offset: 0
# precision: 3
# - name: "MPPT PV Input Active This Year"
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 120
# scale: 0.001
# offset: 0
# precision: 3
# - name: "MPPT Operating Mode"
# data_type: uint32
# input_type: holding
# slave: 170
# address: 172
########## (1) conext_gateway device over Modbus: MPPT600/100 Modbus Slave Address (Port 503): 171 #########
- name: "1 - MPPT100/600 100/600 Device State"
unique_id: af806f9d-8b33-4b7d-9a96-da9dd855cd67
data_type: uint16
input_type: input
slave: 171
address: 64
scan_interval: 1
- name: "1 - MPPT100/600 Charger Enabled Status"
unique_id: 39828bb3-3a76-4806-9177-32c94335fa99
data_type: uint16
input_type: input
slave: 171
address: 65
scan_interval: 1
- name: "1 - MPPT100/600 Charge Mode Status"
unique_id: 7bd2d023-7a64-49ec-8b04-475b8bb52be6
data_type: uint16
input_type: input
slave: 171
address: 67
scan_interval: 1
- name: "1 - MPPT100/600 100/600 Active Faults"
unique_id: 32cd6f85-0a01-4c0e-aa9b-436ac4c2322f
data_type: uint16
input_type: input
slave: 171
address: 68
scan_interval: 1
- name: "1 - MPPT100/600 Active Warnings"
unique_id: a412f704-9b2e-41d5-b3f6-8d86495480c9
data_type: uint16
input_type: input
slave: 171
address: 69
scan_interval: 1
- name: "1 - MPPT100/600 PV Input Voltage"
unique_id: d24417f1-f1d7-4fa6-9cea-3f7fe7479f78
data_type: uint32
input_type: input
slave: 171
address: 76
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
- name: "1 - MPPT100/600 PV Input Current"
unique_id: 1060d494-22f8-417c-bf64-0934d3236b92
data_type: uint32
input_type: input
slave: 171
address: 78
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
- name: "1 - MPPT100/600 PV Input Power"
unique_id: b77f3da9-a88e-4cef-87c6-eadf437d63ca
data_type: uint32
input_type: input
slave: 171
address: 80
scale: 1.0
offset: 0
precision: 0
scan_interval: 1
- name: "1 - MPPT100/600 Battery Temperature"
unique_id: 0b80a457-f2f7-46b9-ab58-289f0b9239d8
data_type: uint16
input_type: input
slave: 171
address: 86
scale: 0.01
offset: -273
precision: 2
scan_interval: 1
- name: "1 - MPPT100/600 PV Output Voltage"
unique_id: b83f4554-d79e-4729-a8f7-6419009612d6
data_type: int32
input_type: input
slave: 171
address: 88
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
- name: "1 - MPPT100/600 PV Output Current"
unique_id: 206f654b-10bf-41b1-9c60-0dd041fba5cd
data_type: int32
input_type: input
slave: 171
address: 90
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
- name: "1 - MPPT100/600 PV Output Power"
unique_id: 3c1eb0ac-bc79-4ec1-93ff-bd4f1408475a
data_type: uint32
input_type: input
slave: 171
address: 92
scale: 1
offset: 0
precision: 0
scan_interval: 1
- name: "1 - MPPT100/600 Energy From PV This Hour"
unique_id: afae5691-933e-451d-95aa-e230fcb1f035
data_type: uint32
input_type: input
slave: 171
address: 112
scale: 0.001
offset: 0
precision: 3
- name: "1 - MPPT100/600 PV Input Active This Hour"
unique_id: b0e058b7-6280-4aae-a246-830df4bddd72
data_type: uint32
input_type: input
slave: 171
address: 114
scale: 0.001
offset: 0
precision: 3
- name: "1 - MPPT100/600 DC Power Output Percentage"
unique_id: 113d1cea-18a6-44ae-ac2e-7ad8002e4c01
data_type: uint32
input_type: input
slave: 171
address: 94
scale: 1.0
offset: 0
scan_interval: 1
2023-12-17 07:21:07.173 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration victron which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-12-17 07:21:07.175 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2023-12-17 07:21:16.519 WARNING (MainThread) [homeassistant.components.modbus.validators] Modbus Victron_GX timeout(15) is adjusted(14) due to scan_interval
2023-12-17 07:21:16.520 WARNING (MainThread) [homeassistant.components.modbus.validators] Modbus EG4_Internal_BMS timeout(15) is adjusted(14) due to scan_interval
2023-12-17 07:21:16.520 WARNING (MainThread) [homeassistant.components.modbus.validators] Modbus Conext_Gateway timeout(15) is adjusted(14) due to scan_interval
2023-12-17 07:21:16.533 INFO (SyncWorker_6) [homeassistant.components.modbus.modbus] modbus Victron_GX communication open
2023-12-17 07:21:16.533 INFO (SyncWorker_2) [homeassistant.components.modbus.modbus] modbus Conext_Gateway communication open
2023-12-17 07:21:16.533 INFO (SyncWorker_0) [homeassistant.components.modbus.modbus] modbus EG4_Internal_BMS communication open
2023-12-17 07:21:26.619 ERROR (MainThread) [homeassistant] Error doing job: Unclosed connection
I have confirmed that anything loaded by MODBUS is lost.
test configuration.yaml
test config.yaml
default_config:
frontend:
# Text to speech
tts:
influxdb:
port: 8086
max_retries: 3
modbus:
- name: Victron_GX
type: tcp
host: 192.168.1.164
port: 502
delay: 2
timeout: 15
type: tcp
host: 192.168.1.179
port: 502
delay: 2
timeout: 15
type: tcp
host: 192.168.1.179
port: 503
delay: 2
timeout: 15
logger:
logs:
homeassistant.components.modbus: debug
pymodbus.client: debug
/sensors/mppt.yaml
MPPT.yaml
- platform: modbus
hub: Conext_Gateway
sensors:
data_type: uint16
input_type: input
slave: 170
address: 64
scan_interval: 1
data_type: uint16
input_type: input
slave: 170
address: 65
scan_interval: 1
data_type: uint16
input_type: input
slave: 170
address: 67
scan_interval: 1
data_type: uint16
input_type: input
slave: 170
address: 68
scan_interval: 1
data_type: uint16
input_type: input
slave: 170
address: 69
scan_interval: 1
data_type: uint32
input_type: input
slave: 170
address: 76
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
data_type: uint32
input_type: input
slave: 170
address: 78
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
data_type: uint32
input_type: input
slave: 170
address: 80
scale: 1.0
offset: 0
precision: 0
scan_interval: 1
data_type: uint16
input_type: input
slave: 170
address: 86
scale: 0.01
offset: -273
precision: 2
scan_interval: 1
data_type: int32
input_type: input
slave: 170
address: 88
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
data_type: int32
input_type: input
slave: 170
address: 90
scale: 0.001
offset: 0
precision: 3
scan_interval: 1
data_type: uint32
input_type: input
slave: 170
address: 92
scale: 1
offset: 0
precision: 0
scan_interval: 1
data_type: uint32
input_type: input
slave: 170
address: 112
scale: 0.001
offset: 0
precision: 3
data_type: uint32
input_type: input
slave: 170
address: 114
scale: 0.001
offset: 0
precision: 3
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 106
# scale: 0.001
# offset: 0
# precision: 3
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 106
# scale: 0.001
# offset: 0
# precision: 3
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 110
# scale: 0.001
# offset: 0
# precision: 3
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 112
# scale: 0.001
# offset: 0
# precision: 3
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 114
# scale: 0.001
# offset: 0
# precision: 3
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 116
# scale: 0.001
# offset: 0
# precision: 3
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 118
# scale: 0.001
# offset: 0
# precision: 3
# data_type: uint32
# input_type: input
# #count: 2
# slave: 170
# address: 120
# scale: 0.001
# offset: 0
# precision: 3
# data_type: uint32
# slave: 170
# address: 172
Can anyone please be of assistance? Or point me to what I am doing wrong?
Thank you!
