Error starting stream, see logs for details (Server failure)
I’ve been getting this error when I tried to watch any video from the media player.
These clips were recorded by Frigate.
I could not find any reference to this error. When I search in my logs I cannot find any references to the term ‘stream’ so I’m not sure what else to search for in my logs.
Any thoughts?
I am experiencing the exact same. Did you ever find a solution for this?
:slightly_frowning_face: no. I’ve just accepted that I can only see thumbnails.
Tip: move to Frigage 12 beta; that solved my issue magically.
I had a similar problem. Whenever my automation switched to the doorbell camera, it would show the stream error message and the video stream would be frozen.
I added a browser_mod.refresh command, which fixed the issue.
It takes a few seconds longer to get to the video, but at least it works.
Here is my automation:
My setup is a Sonoff NSPanel Pro with Home Assistant android companion app installed as well as browser_mod.
Anyone get past this error? I have a lovelace page switch to cameras per an automation trigger, and sometimes get this same error but not always.
Having the same issue, any found a solution?
No I never did. Sorry. :frowning:
sorry to say it but no. It just started working one day and i’ve never found a change that caused it.
Did anyone find the solution for this issue? :confused:
I had a related issue, for which the following worked: https://community.home-assistant.io/t/frigate-recordings-not-working/846892/7 .
I no longer have the issue as it just started working for me one day. If anyone else finds this works for them I’ll mark it as the solution.
