Error starting Z2M. I may tried the impossible. Advice needed
A short(?) story. Aqara Double Rocker broke, bought a new and got a newer revision (WRS-R02). Conbee II and deCONZ finds it but no function at all.
Ordered a ZBT-01. Using it with ZHA. Some progress but still impossible use the buttons for toogle lights. Then I read about Z2M but I can’t run both on same stick. So I ordered a Sonoff ZBDongle-E and figured I use it with Z2M parallel.
Flashed it with Silabs firmware builder. Went from Zigbee (EZSP) 6,10.3.0 build 279 to 7.4.4.0. No luck. Reflashed with, confirmed working, firmware 7.4.3.0 build 0. Still no luck.
Config: Zigbee2MQTT - Pastebin.com
Error: Zigbee2MTQQ - Pastebin.com
What am I doing wrong?
On the other hand, it seems two sticks can’t communicate between its device’s. I was hoping not having to re-pair some 30 units but I guess that what I have to do.
So which way should I go to be able to have a working switch for our light sources? We miss the old Double Rocker.
Thanks in advance for help.
